Hey guyz,
It was a long time comming and it finally happened.
EPA for Intercooler, POD Filter, Bleed Valve, Un-engeneered Modification to Chasis.
Just wondering is someone could lend me a stock airbox so i can this cleared.
Thanks guyz
https://www.sau.com.au/forums/topic/105225-need-to-borrow-stock-r33-airbox/
Yeah, Guess ill have to get it engeneered.
I got till the 17th to get it engineered.
Im now waiting for a letter from the EPA to tell me what time i have to go for the first inspection to tell me what to do, and then for the final inspection.
Annoying as hell
nuh i got a chipped ECU. Cant tell a diff.
Should i get rid of the Turbo Timer too?
turbo timers arent illegal to have, the way you use it is what makes it illegal
it shouldnt be a problem, but if its easy enough to remove, you might as well do it to save hassles
Really, they opened up your ecu. If it wasnt mentioned on the EPA enfingement notice then they might not worry about it, they'll probally check that it has a stock loom and cover. Also for the hole you had to cut get some steel wire, like what is used to re-frunish chairs and couches(because it is very strong) and shape it to the hole you cut then spot weld it around the outside of the hole.The steel wire is about 5mm thick. This will give the metal the strength it needs. I know from experience. Oh and the turbo wont fly.
I managed to survive the Knox hole of hell the other week. It's like taking a drive to South America and hoping for the best!
If you want any further advice you should just ask r32big_boy.. he might as well work for the EPA.. I think he knows more than they do? :)
Some insane person was telling me a couple of weeks ago about how they ran from Pettett once.. craziest story I think I've ever heard :)
They really ought to give him a desk job before he causes a fatality with his illegal chases and what not.
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
