Hi
Just installed a new turbo tonight and went to try the coolant to see if there were any leaks. What do you know, the thing pisses the green stuff out like you're at the movies.
We've brought it down to the bolts going through the banjo fitting and into the turbo are completely different to what they are supposed to be.
Threads are different resulting in a "gap" that lets the coolant out. We've tried 1 set of copper washers, and we've even tried 2 sets of copper washers. No good!
Has anyone got ideas for a VERY VERY quick fix... I need the car ready for a wedding on Saturday so i'll be willing to try any option so long as it works.
Stan
Stan ... your gonna be out of luck i reckon mate ..
you dont wanna be risking your engine over a leak like this, never mind not being able to bleed the system properly ..
tomorrow is friday, you should be able to get the new banjo fittings.
but
do they screw in easy? you dont have to force them??
how big is the leak? are you using the bolts that gop with the banjo fittings?
The bolts go into the turbo, but definitely not easily close to the bottom of the thread.
The leak is a drippage on one side, and a total mess on the other... so I think one side is OK and the other will need some serious gear to get going.
I am thinking that Enzed might be able to sort something out...
Chris, what about getting a few washers in there or even on thick one?
wont help if the leak is through the thread or through the banjo fitting.
have you got copper washers on both sides of the banjo connection..
washer: banjo:washer:bolt ????
Yeah copper fittings in between everything like you have put...
I'm pretty sure it's coming out from the bit that is closest to the turbo and not the banjo. That is
Bolt; washer; banjo; washer; (leak is here); turbo
I only say this as there is an obvious difference in the bolt at this point when compared to the stock bolt. Also, there looks to be a gap. Looks like hte banjo washer isn't even sitting flush with the turbo.
Maybe a couple of smaller reducing washers to make it sit flush/
Bolt; washer; banjo; washer x 3 (or one fat one); turbo?
need to be copper washers so that they are squashed to create the seal... if there is a gap where you state, try another washer .. if it reduces the leak then you might need some sealant in there ... where did you get this new banjo from?
did you test fit it before the turbo went in?
the bolt might be too long for the hole, and causing the gap.. if this is the case then a washer should fix it... try fitting the bolt and see if it stops cos it seems to hit the end of the thread or no
As above sounds more like the problem...would be unusual for the face on a banjo fitting to not be flat, or the turbo for that matter. spose it could happen.
Either bolt bottoming out or your being a pussy and not doing it up tight enough :P
The suggestion of leaking through the gaps in the thread is pretty much impossible when you think about it, well aslong as the copper washers are sealing correctly of course. Don't make me explain, its pretty obvious :(
When you say the thread is different, do you mean different pitch and spacing? or just a longer threaded section so it is bottoming out?
I really hope you don't mean different pitch. If the banjo bolt is simply too long, grind a bit off it. You dont want to pack it with washers.
Had a similar problem when I fitted a new turbo to my RB20 few years ago. Simply went back to the suppliers and got it sorted (bolt was too long, or maybe hole was too short).
Thanks for the advice guys... I think the bolt is too long because in comparison to the original's thread it is a bit longer.
Well we're going to see if we can sort it out - if not we're kinda fuxored!
It's a custom hi-flow system...
The housings are the same as the stock turbo, but the "middle section" is completely different ot the old turbo.
Hence the different bolts.
Thanks
S
OK spark of genuis went through my mind as I was sifting through some parts in my garage. Stumbled upon a "press on hose fitting" or "hose barb" with a thread on it.
We are thinking of chopping the banjo fitting off all together, getting 2 barbs to fit exactly onto the new turbo and using some high pressure hoses to seal the coolant into the new barbs.
Will this work?
The banjo fitting isn't out though... it's still stuck on the coolant line - it's a one piece banjo + line fitting.
We've just been to Enzed to get some new banjo bolts, they seem to do the trick at the moment (going on a lot easier and not bottoming out on turbo)
We've also got some thicker washers from there, the ones we used last night were wafer thin so that may explain some of the issues.
Couldn't find the hose barb I mentioned before, so I hope this is the solution. Bloody expensive banjo bolts I tell you :(
I was once in that situation and the fix was actually very simple . Provided the banjo bolts are too long you can selectively shorten them with a bench grinder so that they clamp the copper washers to the banjo and bearing housing . If you do grind them make sure you clean up the threads before screwing them in .
If you have access to the gas torch heat the copper washers carefully and quench them in cold water , this will soften them if they've been work hardened and help them seal . DO NOT guts the bolts when doing them up , those production banjo's can easily deform and never seal .
Hope this helps cheers A .
I had one worse that that also , had a turbo built from a new bearing housing and one of the bolt holes was not drilled/tapped square to the spot facing - a little late to be finding out .....
Well we just fitted one side of the turbo with the new bolts from Enzed coupled with 2 copper washers on each side of the banjo (one large and one small)
Did a trial water into the radiator test and there is NO LEAKING! Thank god for Enzed :blink:
Did a trial water into the radiator test and there is NO LEAKING!  Thank god for Enzed :O
yes yes <_< go enzed
:lol: ahahha good to hear its fixed up.. when you tuning it?
WOOT!!! Car has been finished :O All in time for the Friday night cruise as well :P
Just like to thank everyone, especially Chris and Aaron for the very very good help and support throughout this! Thanks to everyone who threw ideas at me to try out!
WIND UP THE BOOST NOW BIATCH!
Chris; tune will most probably happen tomorrow or next week... maybe a bit too late to get a booking in.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
