Hi
Just installed a new turbo tonight and went to try the coolant to see if there were any leaks. What do you know, the thing pisses the green stuff out like you're at the movies.
We've brought it down to the bolts going through the banjo fitting and into the turbo are completely different to what they are supposed to be.
Threads are different resulting in a "gap" that lets the coolant out. We've tried 1 set of copper washers, and we've even tried 2 sets of copper washers. No good!
Has anyone got ideas for a VERY VERY quick fix... I need the car ready for a wedding on Saturday so i'll be willing to try any option so long as it works.
Stan
Stan ... your gonna be out of luck i reckon mate ..
you dont wanna be risking your engine over a leak like this, never mind not being able to bleed the system properly ..
tomorrow is friday, you should be able to get the new banjo fittings.
but
do they screw in easy? you dont have to force them??
how big is the leak? are you using the bolts that gop with the banjo fittings?
The bolts go into the turbo, but definitely not easily close to the bottom of the thread.
The leak is a drippage on one side, and a total mess on the other... so I think one side is OK and the other will need some serious gear to get going.
I am thinking that Enzed might be able to sort something out...
Chris, what about getting a few washers in there or even on thick one?
wont help if the leak is through the thread or through the banjo fitting.
have you got copper washers on both sides of the banjo connection..
washer: banjo:washer:bolt ????
Yeah copper fittings in between everything like you have put...
I'm pretty sure it's coming out from the bit that is closest to the turbo and not the banjo. That is
Bolt; washer; banjo; washer; (leak is here); turbo
I only say this as there is an obvious difference in the bolt at this point when compared to the stock bolt. Also, there looks to be a gap. Looks like hte banjo washer isn't even sitting flush with the turbo.
Maybe a couple of smaller reducing washers to make it sit flush/
Bolt; washer; banjo; washer x 3 (or one fat one); turbo?
need to be copper washers so that they are squashed to create the seal... if there is a gap where you state, try another washer .. if it reduces the leak then you might need some sealant in there ... where did you get this new banjo from?
did you test fit it before the turbo went in?
the bolt might be too long for the hole, and causing the gap.. if this is the case then a washer should fix it... try fitting the bolt and see if it stops cos it seems to hit the end of the thread or no
As above sounds more like the problem...would be unusual for the face on a banjo fitting to not be flat, or the turbo for that matter. spose it could happen.
Either bolt bottoming out or your being a pussy and not doing it up tight enough :P
The suggestion of leaking through the gaps in the thread is pretty much impossible when you think about it, well aslong as the copper washers are sealing correctly of course. Don't make me explain, its pretty obvious :(
When you say the thread is different, do you mean different pitch and spacing? or just a longer threaded section so it is bottoming out?
I really hope you don't mean different pitch. If the banjo bolt is simply too long, grind a bit off it. You dont want to pack it with washers.
Had a similar problem when I fitted a new turbo to my RB20 few years ago. Simply went back to the suppliers and got it sorted (bolt was too long, or maybe hole was too short).
Thanks for the advice guys... I think the bolt is too long because in comparison to the original's thread it is a bit longer.
Well we're going to see if we can sort it out - if not we're kinda fuxored!
It's a custom hi-flow system...
The housings are the same as the stock turbo, but the "middle section" is completely different ot the old turbo.
Hence the different bolts.
Thanks
S
OK spark of genuis went through my mind as I was sifting through some parts in my garage. Stumbled upon a "press on hose fitting" or "hose barb" with a thread on it.
We are thinking of chopping the banjo fitting off all together, getting 2 barbs to fit exactly onto the new turbo and using some high pressure hoses to seal the coolant into the new barbs.
Will this work?
The banjo fitting isn't out though... it's still stuck on the coolant line - it's a one piece banjo + line fitting.
We've just been to Enzed to get some new banjo bolts, they seem to do the trick at the moment (going on a lot easier and not bottoming out on turbo)
We've also got some thicker washers from there, the ones we used last night were wafer thin so that may explain some of the issues.
Couldn't find the hose barb I mentioned before, so I hope this is the solution. Bloody expensive banjo bolts I tell you :(
I was once in that situation and the fix was actually very simple . Provided the banjo bolts are too long you can selectively shorten them with a bench grinder so that they clamp the copper washers to the banjo and bearing housing . If you do grind them make sure you clean up the threads before screwing them in .
If you have access to the gas torch heat the copper washers carefully and quench them in cold water , this will soften them if they've been work hardened and help them seal . DO NOT guts the bolts when doing them up , those production banjo's can easily deform and never seal .
Hope this helps cheers A .
I had one worse that that also , had a turbo built from a new bearing housing and one of the bolt holes was not drilled/tapped square to the spot facing - a little late to be finding out .....
Well we just fitted one side of the turbo with the new bolts from Enzed coupled with 2 copper washers on each side of the banjo (one large and one small)
Did a trial water into the radiator test and there is NO LEAKING! Thank god for Enzed :blink:
Did a trial water into the radiator test and there is NO LEAKING!  Thank god for Enzed :O
yes yes <_< go enzed
:lol: ahahha good to hear its fixed up.. when you tuning it?
WOOT!!! Car has been finished :O All in time for the Friday night cruise as well :P
Just like to thank everyone, especially Chris and Aaron for the very very good help and support throughout this! Thanks to everyone who threw ideas at me to try out!
WIND UP THE BOOST NOW BIATCH!
Chris; tune will most probably happen tomorrow or next week... maybe a bit too late to get a booking in.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
