Hi there:
Have a Blitz Blow Off Valve for Skyline R33 GTS with piping, looking for $120 pick up or can be send to interstate, interested email me in [email protected] ask for picture !
(Use this as a guide for new threads. Delete and/or copy the fields as needed - dont forget to add your location in the description field above. Delete this message)
Item:
Item Condition:
Reason for Selling:
Price and Payment Conditions:
Extra Info:
Contact Details:
https://www.sau.com.au/forums/topic/105283-blitz-blow-off-valve-for-gts-r33/
