Hopefully the newer engine might last a bit longer before I have to build a stronger one with forgies etc. Can't wait to get it on to the track - best fun to have in your car legally! We should have a SAUSA track day at Mallala.............
Me too.
The next practice day is on the 24th Feb.
http://mallala.com/practicedays.htm
I think I can attend this one.
Are you free blue32?
Does anyone else want to go?
migh be able to make it - work is ballastic atm! Still gotta install the d-jetro and injectors + tune and then I need some track wheels.......anyone interested in some r32 gtst rims and 6 tyres to suit plus a coupla 17 inch tyres only? I'm after some 17x9 GTR offset rims and tyres for the track. Must have good clearance on the inner rim to clear the 13 inch AP brakes.......
wait till you get it 4 wheel hydroplaning in the wet ! fun.fun.fun. by the way let peter hall dyno the car. he just did my car after another one of my air meter when caput and found martin's tune to be way out in my car. ie tune with martin 263rwk and with peter 292rwk both running 1.1 bar on n1's and power fc
by the way seemed the problem was the timing. need a boost controler so i can hold 1.4 bar and should make 30-50 more kw but dont want to see gear box going bang. 292 is enough for a bit of fun anyway. anyone know if the power fc with hand controler will enable you to switch between 2 settings ie 1.1bar for regular driving and 1.4bar for [HSV i just beat one] floging or giving bikes a go. he he he
You guys were right. Got my D-jetro in and 700cc injectors today and got Martin to tune it - at first it made 291kws and then he went to lunch so I got Peter to retune it while he was out! LOL made another 20kws at the wheels after a couple of minutes in Peters hands. Very stoked with 311kw at the wheels.........
Yeh nice work........311kw in a GTR is VERY usable!
hey blue , just thought i would let you now that my car made 199rwk when it got here from japan stock. had sub zero mick and mark make my exhaust and intercooler plus pipe work and hks dumps and it dopped to185rwk put in the power fc and tune brought it back to 265rwk's on stock turbos with out upping boost. now got n1 turbos and still running standard injectors to make 292rwk's . when i get some spare cash maybe then new injectors and boost controler and then more power. what are you running, turbos etc?
Nah...........just messing with you! Martin tuned it and I'm really happy with it :lol:
Congrats on the number blue
You should wait until both Martin and Peter go for lunch. Keir will tune the car. I think that's how I got 424rwkw :lol: ....or was it Martin :D
Did you use boost 98 fuel?
Did you get Martin/Peter to compare your dynograph with the 32RB26 witb N1 turbo?
Did you get them to compare to my dynograph?
It shoudl be an interesting comparision.
BTW are you coming out to Mallala this Friday? I very sure that I will be there.
Hey guys - I am running the r34 Rb26 -
ARC bigger intercooler
blitz intake cast thingos and filters
sard 700cc injectors + regulator
Pwr FC d-jetro
Bigger fuel pump
Turbos - we figure they are N1s of some description!!! Definantly steel wheel and roller bearing with bigger exhaust housing.
Std dump pipes
std manifolds
Boost 98
Car picked up heaps of grunt across the rev range - 30ish kw at the top end but an average of 60ish kw through the mid!!!
Compared to a std 32gtr: exhaust/filters/1 bar made peak 5400N tractive effort - mine made peak approx 7000N!!! And damn it goes heaps better too.....
Friday - have to do that work thing damn it 9krpm.......but soon as I get some track wheels I'll be there! Isn't it supposed to be 35 degrees???
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
