Monash Uni Liners
Unplug your stock O2, does the problem go away? -
Absolutely amazing level of detail! It's probably worth swapping the sump for a extended/baffled one while the engine is out though
By TurboTapin · Posted
Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it. -
Hey all, The skyline I have is stalling when the engine is at normal operating temp. When starting it while it is cold, it'll run just fine. I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor. Any other suggestions?
Thanks for all the information on this. I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available. Does anyone have any other websites to suggest that I could find the parts? Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
