Hey guys,
im in search of 400awkw in my r32 gtr i am curious tho as to how i would go about making that kind of power without having to much lagg to go with it i am wanting to stay with twins not go a big single for response reasons( i believe it to be correct that 2 smaller twins will get on boost before 1 large single? ) any ideas and/or suggestions would be muchly appreciated
thanx
depends if thats what the parts are going to cost labor will be done my myself and my mechanic so no labor costs was hoping that will bring it down substantially
i was thinking mayb twin 2835r's on custom manifolds with the proper internals and injectors etc but i am unsure and was after some feedback or ideas on what to go with and when it comes to internals which would be best for reliability purposes?
thanx
400 - t04z
search on "t04z"
your gonna need a full rebuild, with at the least a set of good pistons and all the other stuff that goes into a solid motor... and they aint cheap.
Then comes all the extra bits
fuel pump
injectors
ecu (plus addition sensors, depending)
afm's (depending)
clutch etc etc
thats just to get started aswell
Maybe have a search of the RB26 dyno thread too, wont hurt to have a read
My car would pretty much fit the guidelines for that, T04Z on a fully built motor. Comes on quicker than standard turbos did when it was stock.
(PS: Will be for sale soon... engine is 1000km old :rolleyes:, wouldn't wish the costs of modification on anyone, its a long road!!)
Edited by Morgs
if u really wanted to u could stretch 2530s to 400kws. do u plan on running high 10secs?
im planning on using 2530s on a later date keep the twin theme and work on response rather than power. thats wat GTR is about
There is so many setup available now that will provide responce. The only question here is will they provide the target of 400kw? There are single setups and twin setups that will do the job, you will firstly need to choose what type you would prefer as there is no point suggesting a single turbo if you want a twin setup or vice a versa.
As for engine capacity, well if your building a whole engine then you can look at possible increase in capacity, if not then it should not be discussed, what would be the point as you don't have to increase capacity to acheive responce & 400kw.
Twin setup - HKS 2530's are well known for responce and high HP, they'll hit the 400kw+
Single setup - T04Z (HKS or Garrett) Also well known for responce and high HP, seen 468kw with these.
well the shopping list atm looks like this :
arias forged pistons
rods ( unsure which brand to go...suggestions? )
hks F-con V-pro ( most likely i have heard they are better than Power FC at higher power levels that may be wrong tho )
GReddy Plenum
hks 272 cams
hks cam gears
as for fuel i am unsure atm but i am thinking 1000cc injectors are going to be needed and a nice fuel rail so any suggestions on those would be great
this is what i have written down on paper so bits and pieces may change over time when i do a little bit more research
GReddy Plenum
hks 272 cams
hks cam gears
We made 404 AWKW on pump gas with 2530's...28psi. HKS full kit...dumps/mani./piping...5 inch thick cooler...720cc injectors... 3 bosch fuel pumps...Power FC.
Engine was all Nissan except Arias pistons and tomei 260 cams.
What you dont need is the Greddy plenum, 272 cams, rods are only optional as correctly prepped stockers are certainly up to the task...just make sure ARP fasteners are used.
Feel free to pm if you need a hand.
Paul
P.S. We constantly made between 440-460 when pushed with C16 and 34psi.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
