By soviet_merlin · Posted
How come you can get this in new? Is it part of the heritage program? Personally for a hundred dollars difference I wouldn't gamble on another used one. -
By TurboTapin · Posted
Already done, along with confirming all the wiring to the unit checks out. It's more of a wild goose chase in hopes that someone else found a failed solder, bad component, etc. within the unit itself. I have a feeling I'll have to just order a new one. -
See if you can power it up on the bench.
Been getting some good progress on the car over the last week. Everything is now plumbed and wired. We have ECU to TCU comms working. I just need to send through some values from ECU to the dash so I can have a few things showing up there. Fluids are in now and so far so good. Had a couple of small leaks from some hardline fittings but they've been rectified. I found a small leak and tracked it down to fuel slowly weeping from the fuel pressure sensor connector. Will get a new one ordered next week and we should be good to go.
