Does anybody know if the Nismo Keys that are gettin around fit a Stagea?
I asked Nengun, and they said they don't think it will cos the Stagea is similar to the ER34, not a definate answer so i thought someone on here would know for sure.
https://www.sau.com.au/forums/topic/105382-nismo-key/
I've got a nismo key (blank) that l'm using for my other car, which supposedly fits most skyline's, so l'd be under the assumption it would be fine, as l can't see there being much difference between the stagea key barrell & the R33's.
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1943407
Also, make sure whoever cuts it does a good job, as obviously replacing it will be a rather more expensive proposition!!!
I'd probably take it to a keycutter rather than your local hardware store who might cut maybe 2-3 keys a week...
It's not like you've just shelled out for a key that you could have bought directly from the cutter for $2 (or whatever a blank key costs nowadays).
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1947889
Thats exactly what i'll be doing, they should be able to use the number off my original key, and punch it out on the nismo key, i've had that done before.
Much more acurrate than cutting with the grinder when they copy a key.
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1949680
Mines still got the numbers on it ;)
Oh by the way, i emailed Greenline and they have confirmed that the Nismo key, that they and Nengun sell will fit the series 1 stagea, don't know about the series 2 though.
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1963379
on the subject of keys, does anyone know how to program the chip in the key hob to enable remote locking?
i cut a blank nissan key to match the original for a spare. the hob of the key has 2 buttons: lock & unlock.
the newly cut key starts the engine fine (i was suprised!) and now I want to know how to program the chip in the key hob so remote locking works.
sometimes there is a bizarre sequence of actions like insert & remove key 5 times in 10 secs, open/shut door etc.
any suggestions?
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1973013
My cousin had a key programmed for her N16 Pulsar, can't remember where she bought it, but had it programmed by a Nissan dealer.
It might be an idea to ring your local dealer and see if they can do it, surely the sequence can't be too different between models.
Also, I believe there are some places who cut keys who are also able to do the programming for you, if you still can't manage to find the sequence or process to do it yourself.
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1973084
i only got one key with my car, and for some reason it's bent. it still starts the car, but i doubt i could get a key cut for it. some genious has ground off the numbers on the key as well.
to get a key cut fresh, i'm assuming i'll need to take the car to a dealer or locksmith for them to get a number off the ignition barrel?
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1973482
Cool, interesting reading chook! Wonder if it works with aftermarket ECU's, eg PowerFC?
Meh still, when I got my Mongoose alarm hooked up, it disabled the key door lock/unlock from working, good thing I got two alarm keyrings :)
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1973580
Please note that size 10 keys have been discontinued.
Only some places still have the item in stock.
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1974442
  • 2 months later...
Its amazing what u find out about Stageas.
Only today i asked my local M10 for a spare key they said they could cut.
Now i've read this. Hmmmmm! The numbers have been ground off the only key supplied.
This whole Forum is getting like the X Files!
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-2121576
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
