I have the following for sale:
1x Radar Detector, Cobra ESD 9100, $sold
1x Paintball gun (tempest), with full gear $350
1x 300wt 12 volt inverter (convert 12v to 240v, for incar pc etc) $50
1x 5 port hub, intel, $20
1x New Leather Gearstick boot (for skyline) $sold
I have more stuff @ home, ill add it once I check whats avaliable
How big is the radar detector?
Can you leave it permanently under your seat or must it be sitting up on the dash ?
How long have you had it ?
How does it get 'tuned' for Au ?
What sort of range does it have ?
Ive had it for a few months, It detects cop cars from about 1km away, speed cameras vary from 300mtrs to 100mtrs.
Aus uses different frequencies, this one has been ajusted to pick up the aus cops. There is a small ajustment screw inside of it, dont know how they do it exactly though.
I presume it can go anywhere in the car, just works better on the dash, ive had it working when it was sitting in the passanger seat
$100
  • 4 weeks later...
  • 1 year later...
    • C34 Stagea RS4S Standard RB25DET Neo with ARP Headstuds and MLSR Gasket. Bosch 1000cc injectors Walbro 460 Standard neo inlet plenum w/rb25 s2 throttle body 6 Boost Low Mount Manifold Turbosmart Gen V 45mm wastegate (recirculated) Pulsar g30-770 (0.72 rear housing) 3.5"intake pipe to clear mounts, 3.5" dump to 3" exhaust Link G4X Ecu 380 hp on 98 octane, 478 HP on e85 (mainline hub dyno) Video of Earlier Run VID_300701109_043404_458.mp4 Final Dyno Sheet:
    • Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
