Hi all, just wondering how many of you's out there have wound some boost into your cars?
We run 10 pound all day everyday.
What is everyones idea of a safe boost level to run?
Also what sort of fuel ecconomy do you guys get now?
https://www.sau.com.au/forums/topic/105442-what-boost-do-you-run-in-the-stagea/
... you's ....
Sorry, firstly a pet hate of mine, it's 'you', plural and singular.
And on topic, i run my bleed valve at 10psi as over that the stock stagea computer has a fuel cut and the car jerks around. not a fun experience.
I'm getting about 350 - 370km to a tank city driving and over 450km to a tank country driving
I've got the jaycar IEBC set at 10 pound on high boost setting. With the stock (well I've got an R34GTT but close enough) intercooler and turbo I won't run any higher than this. I also doubt if I did I'd get much more power anyway. As it is even though my guage only just flickers about the 10 at times I still hit boost cut when I push hard between gear changes (auto).
i'm not having a real fun time with fuel atm as most people here will tell you. If I can get it over 300k's city i'm doing well atm. But I've only just bought it and am now learning how to drive it for better economy (= baby it). on my current tank i'm at 70k's and in between 3/4 and full so its looking better already.
mine is running 11 with the uni chip, seems much better than standard but missing under load, think its the coil packs. getting about 280 to 300kms a tank city driving, but i do have a bit of a heavy foot
It's prob a good idea if you add if you have the standard turbo, exhaust & any other mods.
Mine is stock except for a splitfire filter, & i run around 10, but i find at around 5000rpm it feels like a stutter in the power band & i got no idea what it is?
0 boost for the last 8 months haha, and before that was 18psi with 350rwhp for about a month, and before that it was stock 7psi with the rb25.
soon to run 17-18psi as a base tune, and then in a few months hoping to put in over 2bar and push the t04z to its limit :D
Well currently I'm running 8 - 9psi...
When I get the Jaycar IEBC installed etc. I will be running 10psi low and 14.7 (1 bar) on high.
Fuel economy sucks :P Cant really get over 350 no matter how hard I try
Once I get it tuned properly I want to run about 10 psi, as the stock rb25 turbo's do not respond well to anything over 1bar for prolonged periods, or so I have been told and read on here, (there are thousands of threads on this subject).
But I was getting about 400kms out of a tank, but that was with the pfc tuned with a blocked radiator at the time, so it was tuned stupidly rich.
I have to clean the back screen at least once ever three to four days otherwise it gets blocked by that unburnt fuel soot :(
Hopefully in the next couple of weeks it will be tuned properly on 10psi, and I will be aiming for ~500kms out of the tank, hopefully :P
Quote SKA -
I have to clean the back screen at least once ever three to four days otherwise it gets blocked by that unburnt fuel soot"
Q was, what is the back screen? is it just the rear window?
I thought at first it may have been something on the intake causing your fuel rich problems. I suppose I had in my mind what others have said about cleaning their AFM's.
I just wanted to be up to speed with my servicing before it became a problem.
After reading some of these threads it seems that most people have a squeak/rattle or misfire problem somewhere. Everytime I drive mine I listen out for things and have yet to fault anything. (except for the noise in my left ear saying "slow down you've got kids (3) in the back!")
It runs flawlessly and I love it more each time I drive it.
OH OH OH Sorry :D Rear Screen = Rear Windscreen :)
And its the whole back door and rear bar, that whole area gets covered in black soot, but I am sure it is because I am running stupidly rich, I leave a HUGE black cloud of fuel smoke when I do launch it :D
Currently running 10 psi controlled by the IEBC with the DFA tuned (~11 to 1 A/ F ratio) which was as good as we could get it with the standard exhaust. The R34GTT intercooler is fitted but the Magic cat is still in the garage with the 3.25” exhaust. Plus the SITC is fitted, but untuned, it is waiting on the exhaust.
Now that the project R33GTST is serviced, registered, suspended, PFC’d and running hard and fast, I might be able to get back to the Stagea. There is also a GCG ball bearing high flow and a split dump/engine pipe to go on.
BTW, It was pretty useless running more than 7-8 psi without the DFA, the standard ECU R&R mapping made it slower than when it ran 6 psi.
:D Cheers :)
Edited by Sydneykid
Running 12psi. All fully tuned.
Full exhaust, fmic, NEW oxygen sensor (for best fuel economy), pod filter, sitc, safc, ebc etc etc.
Get over 420km per tank (hitting resevre), with 160awkw.
Great pick up at 5000rpm, no splutter for me - a nice safe tune, rarely do I let it stay at 12psi....... (heat factor = dead turbo).
Got a spare turb' sitting on the shelf.......
my car is completely stock except for the 3.5" exhaust, front mount, and pod filter.
plannin some more mods down the track.
but I don't wanna go crazy.
keepin in mind that this is my daily run about family car.
if my other half had his own way it would have had a turbo upgrade and computer by now.
but in the end it's my car and the foot comes down...
lol....
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
