Hi all, just wondering how many of you's out there have wound some boost into your cars?
We run 10 pound all day everyday.
What is everyones idea of a safe boost level to run?
Also what sort of fuel ecconomy do you guys get now?
https://www.sau.com.au/forums/topic/105442-what-boost-do-you-run-in-the-stagea/
... you's ....
Sorry, firstly a pet hate of mine, it's 'you', plural and singular.
And on topic, i run my bleed valve at 10psi as over that the stock stagea computer has a fuel cut and the car jerks around. not a fun experience.
I'm getting about 350 - 370km to a tank city driving and over 450km to a tank country driving
I've got the jaycar IEBC set at 10 pound on high boost setting. With the stock (well I've got an R34GTT but close enough) intercooler and turbo I won't run any higher than this. I also doubt if I did I'd get much more power anyway. As it is even though my guage only just flickers about the 10 at times I still hit boost cut when I push hard between gear changes (auto).
i'm not having a real fun time with fuel atm as most people here will tell you. If I can get it over 300k's city i'm doing well atm. But I've only just bought it and am now learning how to drive it for better economy (= baby it). on my current tank i'm at 70k's and in between 3/4 and full so its looking better already.
mine is running 11 with the uni chip, seems much better than standard but missing under load, think its the coil packs. getting about 280 to 300kms a tank city driving, but i do have a bit of a heavy foot
It's prob a good idea if you add if you have the standard turbo, exhaust & any other mods.
Mine is stock except for a splitfire filter, & i run around 10, but i find at around 5000rpm it feels like a stutter in the power band & i got no idea what it is?
0 boost for the last 8 months haha, and before that was 18psi with 350rwhp for about a month, and before that it was stock 7psi with the rb25.
soon to run 17-18psi as a base tune, and then in a few months hoping to put in over 2bar and push the t04z to its limit :D
Well currently I'm running 8 - 9psi...
When I get the Jaycar IEBC installed etc. I will be running 10psi low and 14.7 (1 bar) on high.
Fuel economy sucks :P Cant really get over 350 no matter how hard I try
Once I get it tuned properly I want to run about 10 psi, as the stock rb25 turbo's do not respond well to anything over 1bar for prolonged periods, or so I have been told and read on here, (there are thousands of threads on this subject).
But I was getting about 400kms out of a tank, but that was with the pfc tuned with a blocked radiator at the time, so it was tuned stupidly rich.
I have to clean the back screen at least once ever three to four days otherwise it gets blocked by that unburnt fuel soot :(
Hopefully in the next couple of weeks it will be tuned properly on 10psi, and I will be aiming for ~500kms out of the tank, hopefully :P
Quote SKA -
I have to clean the back screen at least once ever three to four days otherwise it gets blocked by that unburnt fuel soot"
Q was, what is the back screen? is it just the rear window?
I thought at first it may have been something on the intake causing your fuel rich problems. I suppose I had in my mind what others have said about cleaning their AFM's.
I just wanted to be up to speed with my servicing before it became a problem.
After reading some of these threads it seems that most people have a squeak/rattle or misfire problem somewhere. Everytime I drive mine I listen out for things and have yet to fault anything. (except for the noise in my left ear saying "slow down you've got kids (3) in the back!")
It runs flawlessly and I love it more each time I drive it.
OH OH OH Sorry :D Rear Screen = Rear Windscreen :)
And its the whole back door and rear bar, that whole area gets covered in black soot, but I am sure it is because I am running stupidly rich, I leave a HUGE black cloud of fuel smoke when I do launch it :D
Currently running 10 psi controlled by the IEBC with the DFA tuned (~11 to 1 A/ F ratio) which was as good as we could get it with the standard exhaust. The R34GTT intercooler is fitted but the Magic cat is still in the garage with the 3.25” exhaust. Plus the SITC is fitted, but untuned, it is waiting on the exhaust.
Now that the project R33GTST is serviced, registered, suspended, PFC’d and running hard and fast, I might be able to get back to the Stagea. There is also a GCG ball bearing high flow and a split dump/engine pipe to go on.
BTW, It was pretty useless running more than 7-8 psi without the DFA, the standard ECU R&R mapping made it slower than when it ran 6 psi.
:D Cheers :)
Edited by Sydneykid
Running 12psi. All fully tuned.
Full exhaust, fmic, NEW oxygen sensor (for best fuel economy), pod filter, sitc, safc, ebc etc etc.
Get over 420km per tank (hitting resevre), with 160awkw.
Great pick up at 5000rpm, no splutter for me - a nice safe tune, rarely do I let it stay at 12psi....... (heat factor = dead turbo).
Got a spare turb' sitting on the shelf.......
my car is completely stock except for the 3.5" exhaust, front mount, and pod filter.
plannin some more mods down the track.
but I don't wanna go crazy.
keepin in mind that this is my daily run about family car.
if my other half had his own way it would have had a turbo upgrade and computer by now.
but in the end it's my car and the foot comes down...
lol....
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
