can it affect fuel economy?
i noticed in another thread that a guy got an extra 50/100 ks to a tank of fuel by replacing his charcol cannister
my fuel economy is attrocious and i know my charcol cannister isnt hooked up . .. .
https://www.sau.com.au/forums/topic/105461-charcol-cannister/
  • Replies 77
was reading on another forum that
before i was gettin like 300, until i replaced the charcole canister.. seems to better now..
ive replaced my o2 sensor and fuel economy hasnt changed from 300ks a tank (regardless of how i drive, regardless of low or high boost)
gets slightly better with highway driving
Is the speedo correct? As Im guessing thats the only way you can tell your kms. That or you might have a fuel leak... Maybe. Done all the injector cleaning etc?
[edit]
I dont think a charcoal canister will affect things that much either. I mean mine isnt hooked up, yet Im on 535kms and my fuel light isnt on yet...
yer, speedo is correct, havent done injector clean, but will do
was really hoping the o2 sensor woudl fix economy, but its made no difference at all
strong fuel smell reversing the car up the driveway, and apparently it did have a fuel leak, but piping was repaired
cant smell fuel in the boot at all though
Could be somelike like an injector seal? Who knows dude.
But a charcoal canister has to do with the emmissions control. It is illegal to have it disconnected. Has something to do with fuel vapour or something from memory. Dont quote me on that tho.
I have the same problem with my GTT...went at most 360km full tank...haven't done anything..but I'm going for the power Fc approach..
I'll be tuning my car on the 21st...will prolly know the difference with the fuel consumption a week after..I'll keep update..
My car uses a hell of a lot of fuel compaired to other cars as well. I normally get between 300/350 city driving and 400 highway.
Even when we drove to cairns, the car still only got 400km per tank. Yes admittedly there were places where we weren't doing the speed limit... but I still would have thought that it would have got more than 400k per tank :S
yup, that sounds about the same as mine
i dont get why we are getting such bad economy, yet other skylines making more power in some cases, get much better economy
the bloody car costs me enough as it is, just keeping it on the road, would be nice to get a petrol break, and squeeze an extra 100ks out of the tank
Maybe get a PFC retune?? My new car has a PFC and I get awesome ecconomy (411ks out of 35 L :D ) The new car gets no fuel smell at all where as the R33 you could smell it all the time (Stock ECU) I think engine managment would be the main factor that effects fuel ecconomy
what power you making bunta?
retune :D
wifey wont like it;
ive already spent hundreds of dollars on tunes (switched exhaust, retune was another 300 on top of the origianl 600)
surely for that amount of money, it wouldnt just be a power tune :)
was done at mercury
Edited by Spook's_Skyline
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
