when people are saying 400 k's to a tank, is that 400k's till your fuel light comes on? or 400k's all up?
My fuel light comes on at ~400k's, but there is still 10L left once that happens, so theoretically I could get another 80 or so k's
  • Replies 77
The best way I have found to gauge fuel consumption is, fill the tank full, reset the odo, run it till almost empty (doesn't have to be when the lights on), when refilling next look at how many litres you need to get back to full then check how many ks you've done. That would be the most accurate way to say how many ks you get per litre.
Same here, as Erin, for a few dollars versus pushing the car or walking along the highway. I'll think I'll pay the extra money to be inside cruising along with the A/C on. But I'm lucky to get 300kay/tank
i get about 400 to ~48litres, i've never run it till the light comes on
however since my mercury tune i've been blowing more smoke than a woodstock festival and people who drive behind me complain of stinging eyes
also i get loud backfires from shifting from 1st to 2nd and 2nd to 3rd about half the time
however i just give whoever i just scared a wink like i meant it
I get those figures - seems 350-400ks per tank depending on the amount of city/highway driving. A/F ratos are perfect on the last dyno run i did (only about a month ago).
I think theres a few people on here that pull the 500k figures out of their probervials. Maybe i'm wrong (which i'll readily admit), or maybe their cars run dangerously lean.
I also remember reading an article in HPI where they guy that used to own a soarer that writes in the mag (maybe martin donnon??) was talking about the issue of warming up your car for 5 mins vs just turning the key and driving straight off. Concensus was it was waaaay better for fuel econ to just drive off as the car runs rich as when cold. Hence it was better to go Maybe its relevant in this case- like a temp sensor or even a thermostat problem -car is colder or at least thinks its colder than it is so runs rich for a longer period.
Oh i too get the fuel smell from time to time, no leaks i could find either.
Another point would be the issue of atmo bov vs plumback. Maybe thats causing problems too???
i think we should
i love my car, but its sending me broke
i need some money back
ps i still use the stock bov
my fuel economy seems to have gone out the window with my fmic install
also got a forward facing plenum with ford throttle body at the same time
i think we should
lol must be the ford tb then, is it carved from stone :P
Seriously tho i too would welcome any help that can be offered.
Well my a/rs are spot on 12, its almost a straight line. And no joke I got 530kms BEFORE my fuel light came on the other day (90%highway driving) and then it was 610kms before I filled up. Keeping in mind I have a heavier car than most of you, and a smaller engine, which should mean more load and more fuel used.
So, dont mean to be harsh, but for some of you maybe its your driving style?
But I do belive spooks and 53xyn really have a problem.
yup, my afrs are almost spot on 12 as well
doesnt seem to matter if i put around on low boost not boosting
or drive around on high boost not not boosting
perhaps a bit of highway running gets me slighter better returns, but id be lucky to see 400ks from a tank (nearly got 400 driving back from stanthorpe)
also, my charcoal cannister was also unhooked when i had the fmic/plennum done
hence the original post
im going to get my cannister hooked up again anyway, just to see if it makes a diff;
Edited by Spook's_Skyline
My GT-T at the moment is getting just under 400kms per tank (55L) and I think that's pretty bad :( I'm keen on knowing if there is a quick and simple solution to this...
I've noticed that the bigger turbo has helped improve it a bit (especially in the city) due to the lag. Not on boost as often :P
But yes, quick and inexpensive fix - bring it on!
I challenge anyone to take up my offer.
I will come out (you pay for fuel and it must be in brisbane) and if I can't fix the problem or tell you what the problem is...you don't pay me. Anyone getting 400k's or more can bugger off coz you aint got problems cept the right foot.
Edited by 3lit3 32
Stan,
GTTs have a 65L fuel tank, so you should get another 100Ks plus minus. I get close to 600Ks on mine B)
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
