Yeah, but the question is can you ever fit 65L into the tank :P
I usually fill up before the orange light turns on, or just as it turns on. With the new fuel pump and upgrades, I'm afraid to even let it sit at the 1/4 mark - it's always above half tank.
Must get a tune soon :(
  • Replies 77
what power you making bunta?
retune :P
wifey wont like it;
ive already spent hundreds of dollars on tunes (switched exhaust, retune was another 300 on top of the origianl 600)
surely for that amount of money, it wouldnt just be a power tune :(
was done at mercury
Spooks I make 200 rwkw on the dot, However I think that having the RB25 in the lighter car (R32) would lend its self to better ecconomy, I find a lot of the time I am using around half the throttle that I used in the R33 for similar accleleration (R33 also made less power)
How could you not fit 65L into a 65L tank.
When the light comes on..you should be able to drive approx 100km more before the car will stall.
I'm just curious as to how people are measuring their distances. Surely you don't just fill it up and then read the odometer when the light come on.....that's just silly.
The only accurate way to measure the right distance is to fill it up completely to the brim and then drive 100km. Then pull into the nearest servo and fill it up to the brim again. Note down the number of litres you have put in....it's as simple as that.
The car is heaviest on a full tank so the fuel economy is its worst when the tank is full. Don't cain the crapper out of it for 100ks either, and don't baby it...just normal driving...boost it regularly. Then post up your results. I am willing to help those in need but no-one has taken me up on the offer yet.
The only reason I suggested the tune was because on my old r33 gtst I was pushing 300kms out of a tank, thanks past the light and waiting till it coughed.
Anyway I bough a SAFC and took it into Mercury for a tune and BAM gained 15rwkw and consistently got 550-600kms out of the tank!
My problem is that the skyline only get driven hard. If I was going for fuel economy, I'll just drive the office prius, it get over 1000k/tank and take 500 metres to stop from 100k/hrs. Tyre are as hard as Steel.
But if you have ongoing bad fuel eco, get a smoke test done and a good tune will fix all. but $500-750 in difference of fuel eco, buys alot of fuel. Oh wait I don't have to pay for mine.!!!
I had a similar problem with bad fuel economy and fuel smell.
I traced the problem back to the aussie fuel filler/nossle from the compliance process. seems the dodgey bastards hadnt fitted it properly and it had become slightly loose and alot of fuel was evaporating whilst the engine was running.
I simply removed it, cleaned it down and used a strong fuel rated sealant such as sikaflex. I got alot better fuel economy and lost the fuel smell.
matty
Hmm maybe a SAFC is the way to go.
I have a stock GTT and was getting 400-450kms (mixed city and freeway) before the light came on, a few months after now getting 350 to maybe 400, pure city driving though. Dont know whether this sounds right but I do know other GTT's, especially modded ones are getting more. I drive OFF boost almost 99% of the time.
So yes, Id like to know whether there is a fix for this? perhaps a SAFC might be the way to go. Ill also chuck it on the dyno to see how the figures turn out.
That's deffinetly the best way to measure your fuel consumption, i did a couple of Thursday's ago had 11 pound, 35k's highway the rest was fairly spirited, pulled into the servo and got 12.3 L i was pretty happy with that, is this more what your trying to get spook's
within the powerfc, drop the injector duty cycle down by xx %
remember, it will run leaner across the board (so more knock, perhaps?), but is the easiest way of 'retuning' it without taking it to a tuner ?
Anyway, i couldnt be bothered reading all the 3 pages, so it may help ?
Or drive it off boost. with my car i managed 450 city kms when keepin it under 0.2 bar of boost. boring as hell to drive. Mind you the other day i ended up going for a bit of a thrash and did 200kms on a tank (whoops)
oh and managed to chew up most of the fuel when i was at oran in under 100kms :P
happens when your duty cycle hits around the 92% mark on 700cc injectors
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
