u could just tell us what causes bad fuel economy
I have two thoughts now, if your afrs are near on that 12.
The 12s are on WOT tune, so everything in between that and idol sucks ducks nuts. meaning drinking fuel as you dont drive round with your foot flat all the time.
2nd thing could be a fuel leak still, which would mean it could still be tuned properly. Just the fuel isnt all making it to the engine.
  • Replies 77
yer, it doesnt seem to matter whether i boost it or not, my economy is still bad
which leads me to think its something else
i would hope that the tune was done propperly, coz it cost a f**king fortune, surely i shouldnt have to tell my tuner to tune not just for WOT but for normal driving as well????
the economy was bad with the stock ecu anyway, so im pretty sure that the tune, while it may not be helping, isnt the issue
there is always a strong fuel smell when i reverse, but i can never smell fuel in the boot area after running the car
im interested in the evaporation issue the aussie fuel filler/nossle issue that was bought up before, and i pm'd the guy from nissan silvia who fixed his economy by replacing his charcoal cannister (he reckons he did nothing else) so, im going to hook mine up again also
my o2 sensor is brand new
ive had a heap of fuel hoses replaced as it was discovered that they were perishing (along with every other hose in my engine bay that ive had replaced)
this problem just seems to common, so many of us suffer from such bad economy
i want to know what causes it and how to fix it
spook i have no canister and i can get a bit over 400km with normal driving (which includes a bit of boost)
i got 350km last tank and that included a whole lot of boosting over glorious
can you pull up o2 sensor readings on your pfc? have you cleaned your afm recenty?
yer, ive been watching the o2 sensor readings on the hc
seems to be working correctly
i havent cleaned my afm
woudl it being dirty affect its readings?
ill check and see what sort of voltages its reading;
Maybe get a PFC retune?? My new car has a PFC and I get awesome ecconomy (411ks out of 35 L ;) ) The new car gets no fuel smell at all where as the R33 you could smell it all the time (Stock ECU) I think engine managment would be the main factor that effects fuel ecconomy
damn, some of these posts are crazy, the other day i got 350km with 36litres, and i have a stock ecu, with other mods, i have a power fc waiting to go in, these posts are sorta scaring me puting it in and tuning it :)
Spooks,
Go back to MM and get them to look at it firstly. I think that you should give them an opportunity to explain.
On a side note I had my PFC tuned there and am quite happy with the fuel economy, granted I mainly drive it on weekends and it is warmed up before every drive and then cooled down...
yer, im not convinced its the tune
fuel economy was bad before the pfc (350ks to a tank, with just exhaust, dump pipe, fmic and plenum)
im going to get my mechanic to check a few things out for me next service and see what he comes up with
then im going to get in touch with elite and see what he says
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
