Item: R32 GTR gearbox with PPG helical 5sp dogbox. Gearbox has just been rebuilt by Dale Koenecke at K&A motorsport. Gearbox has brand new 26 splines PPG input shaft, brand new nissan output shaft, brand new bearings, billet selector forks, 2nd gears only used for around 100km, all other gears has been cracked tested by Dale. Almost new gearbox that has been in a medium powered R32, car has not been to drag strip at all.
GEARBOX IS SOLD
Item: Titanium catback exhaust
Item Condition: Excellent. Only blue at the tip and one of the bend, so it has not been used that much.
Reason for Selling: Not needed. A bit loud for my taste.
Price and Payment Conditions: Offers above $750
Extra Info: Not for the reserve guy like me.
Item: 6x stock R32GTR 440cc injectors
Item Condition: Used.
Price and Payment Conditions: $350 ONO
Item: Blitz blow off valve
Item Condition: Used, still functional and just removed off the car.
Price and Payment Conditions: $250 ONO
Extra Info: This is loud :D
Item: Stealth FX GFB BOV
Item Condition: Reconditioned by GFB recently and has not been used on car. Good as new. Come with universal and 200SX fittings.
Price and Payment Conditions: 350 ONO
Extra Info: Variable noise control
Item: 2x 80mm Nissan MAF.
Item Condition: Bought new, used for 1 year or so, weekend car, low km. Excellent condition. I will check if I can remove the harness as well.
Price and Payment Conditions: $250 each
Extra Info: Bang for buck mod
Item: 38mm Tial Wastegate.
Item Condition: Bought new, used on the s2k for around 1-200km. Had boost creep. Replaced with larger one but boost still creep ie poor manifold design.
PM or drop me an email [email protected]
Edited by 9krpm
Titanium exhaust is a one piece 3" pipe welded to a titanium muffler with 3.75" tip from Japan. Costed 1800 about 1 year ago.
I will take some pictures later when the battery is charged.
hi mate, i think you may need to host the pics somewhere that doesnt need password access. you can host them here at SAU if that helps.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
