(Use this as a guide for new threads. Delete and/or copy the fields as needed - dont forget to add your location in the description field above. Delete this message)
Item:
Item Condition:
Reason for Selling:
Price and Payment Conditions:
Extra Info:
Contact Details:
R33 GTS-t, Black, 5 spd manual. Front Mount Cooler, BOV, 3 inch Exhaust w/Dump pipe. Apexi Power FC, Bosch 800hp fuel pump, Surge tank and fuel regulator. High Flowed charger. Brass button Clutch. Boost gauge and pioneer head unit. Entire car is in VGC, interior is in excellent condition.
Price: $18000 ono or will consider swap for ute or 4wd with cash adjustment in my favour depending on the vehicle.
Extra Info: Selling registered but will only obtain RWC and Safety Cert. after receiving Deposit.
Contact Details: 0406280287 or [email protected]
https://www.sau.com.au/forums/topic/105542-r33-gts-t/
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
