hi guys ive got an r32 gtr heavily modified from japan for track use i think or drag use, i was hoping if anyone can help me out with a little problem ive been having, the car kinda stalls when the oil pressure drops. however when the car is flying hard theres no problems at all only somtimes when i go from gear straight to nuetual, if anyone has the same problem pls let me noe.
by the way the oil filter is no longer on the block its got i think a grex high oil pressure regulator or somthing like that, the braks are really sqeeky n is kinda annoying help plz...............
thanks guys
https://www.sau.com.au/forums/topic/105557-r32-gtr-stalling/
The oil pressure drops to nothing because the engine is stopped and so not pumping oil around. It can drop to as low as 10-15psi at idle depending on engine speed.
It is probably stalling because you have short intakes and the afm's are copping a bit of reversion off the comp wheel of the turbo. It's not a major issue.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
