Membership Cards and Stickers, check if you are on the list
I have Membership Cards and Stickers for the following people:
cereal
Merli
OzGTR97V (Paul L)
Roy
Akira
Not sure of nicks for the following:
Mark Hayden
Adam Kovacs (Zane?)
Rhys Wheeler
if you guys all came on the cruise today you would now have them...:lol: :)
We'll have to have a meeting to distribute them.
Originally posted by brendanf
Rhys=skylark
Mark=MRK25T
me thinks ... ... .. .. .. ..
Originally posted by red900ss
Adam Kovacs (Zane?)
correct :uh-huh:
I sent a group email too, so everyone should be aware they are ready.
hey bigvis, send me your email and i'll send you back a form :)
then you can either hand it in to one of us at the next meet, or mail it to the PO box...
my emails in my sig :(
Merli: Dino's away till the 25th, so he won't be at the steak night ;)
MRK25T: the email you put on your form is [email protected] so check there :D Do you want me to change it to that other one you posted for any future emails?
Neil...if you only sent your form in recently, it's likely that it's with Christian and therefore you will be included in the next lot of cards/stickers...
Ahh, sorry about that Shell.
With that hotmail account I get a massive amount of junk mail.
I select all the emails, and then my checking the 'from' field I unselect the ones that have come from people I know.
Looks like i've deleted the email by mistake.
If its not too much trouble could you change it to the optus email address for me please? [email protected].
I assume christian told you that i've paid - you looked too busy on the 'gong cruise so he took the money.
regards,
Mark
Dino, that's Brody (see above, he wants it posted). I'll email you his address.
broken :bahaha: :bahaha:
yep i sent them from Fyshwick PO hehe
sorry if anyone got in trouble cos their other half thought it was porn LOL
MRK25T, no probs, I've changed it ;)
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
