Last year i had my car painted in a similar colour to a Candy Apple Red. I then bought a spare rear "SKYLINE" facia and had it painted with the car.
The project was off and on for some time till now. Last week i decided to complete the facia and mount it on my car. Here is a brief discription of the work invloved and pics of the finished project.
After the spare "SKYLINE" facia was colour matched, i first used my Dremal tool to cut out the rear of the facia. In hin-sight it may have been better to complete the unit first, before painting, but time was an issue.
Then i used a sharp blade, off a Stanly knife, to gently cut off the paint from each letter. (Not as hard/long as i thought it would be :cheers:).
Using a Jaycar "bread board" and my electronic experience, i positioned two hi-intensity LEDs in between each letter. This was done to try and minimize the focus of the LEDs. YES, it is damn bright :rolleyes:; i may disconnect one wire and only use one LED between each letter.
It is now ready to be secured into position, using "Loctite 406 superglue", then i will coat it with sicaflex to ensure it is as water resistant as the original.
As stated above, i used Sikaflex to seal the board into the facia. When mounting the facia i had to remove one of the four bolts to allow the wires to enter the boot. I fastened the ground wires to an existing GND and spliced the +ve wire to the parkers (on the brake light assy). I didn't use any relays as i figured 0.3Amps for the whole circuit isn't a heavy load on the existing factory cabling.
Here are the completed pics:
https://www.sau.com.au/forums/topic/105568-skyline-backlight/
Good job Al, looks good. I saw one done in a aqua blue once in a mag. Think it was HPI, cant remember.It was a few years ago.Looks like you have created some work on the side :D Every little bit helps when you own a line :D
Thanks guys :) I too agree, it's very ricey, has no real purpose but to be ricey, but it looks damn good :lol:.
Lights are hooked up to the "tail lights" and only come on when the headlights are turned on.
Forgot to mention; even though the facia is heavily painted the dots still appeared through the other side. So i stuck some black door jam strips in between each letter, on the inside.
I have seen the factory fitted backlight and am not a fan of the green light, especially with my candy red paint :lol:. I chose red to match the tail-lights, hopefully i wont get hassled as i have seen factory cars with the whole tailgate lite up red.
Even though i did this myself it is by no means a cheap project.
- Facia $40
- Prep (facia was previously poorly painted) and paint $80
- LEDs, resistors, circuit board $50(approx)
- Sikaflex $16
- Consumables $5
TOTAL: Approx $190 :P
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
