Hi Guys,
Just installed a stereo on Saturday and having serious power issues! <_<
Installed - Pioneer Headunit 52W x 4, 6x9's & 5x10's
Stereo display 'dims' :D when a a bit of bass if passed thru and volume up but as soon as I turn on my headlights the entire unit shuts down. :D
I checked and power is being fed to the headunit while lights are on but obviously not enough.
Would i be correct in stating that my battery is not supplying enough power as the headunit display is 'dimming' shutting down once power is being fed elsewhere??!!
Fix???? Any help / advice! :(
Thanks in advance
Ando
Sounds like a power issue. Either a shonky battery, or a shonky alternator, or a shonky ground on the battery.
First thing to try is re-grounding the battery. Replace the negative cable with a new one, with new ring-clamp things, and clean up the area that it bolts to the chassis. This should fix a lot of things, but failing that, check your battery out. =-]
Hey thanks dude!
Fixxer - Mate this is both when the car is running and also when off! (in accessories)
Battery is actually a bit old and a little smaller than normal only just takes up half of the battery plate.... :P
RANDY - Mate yeah a mate is gonna lend me his battery next time and see if it solves the issue! Just wanted to make sure it wouldn't be anything more than just a battery / alternator
Cheers guys :(
Ando
you could also try running a thicker gauge constant power cable straight from the battery (with a fuse of course). but other than that i would be checking your earth point for the unit as well as the battery earth terminal is clean, and has good earth from the battery to body.
where did you pick up your earth from i bet you picked up the dash light illumination thinking that it was earth usiing a test light happens all the time just whip the unit out and put the (guessing) black wire straight to metal of the car
then try it
my 2 cents
cheers
A simple test for your alternator is to have your head lights on and rev the car. If the brightness of the lights increases with the revs then it will prob be an alternator problem as it's not supplying enough power at idle etc
Skybee has a great point that I thought was too obvious to point out.
The head unit should be grounded to the body, and you should never have to splice into another wire for anything.
And when I said "try replacing the ground wire", I should add; "with a much thicker one". =-]
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
