basically when i have stopped and am starting to move again turning i.e stopped at a set of lights to turn when i start moving i get shuddering but stops when i either go straight or when spped /revs increase
is especially bad in reverse sometimes (think cause the turn is tighter)
now it feels like it coming from the diff (like diff chatter i.e tight diff, but i got stock diff)
and as soon as i put the clutch in again shudder stops immediately so only happens when on load
the particulars are R32 GTR, i recently changed gearbox (sychros gone in old box)
have checked power steering fluid was a low but i filled it and prob still there could it be pump??
and i know something is wrong with 4wd sometimes when start car 4wd light will come on and 4wd will not work to fix it can just turn car off and on again and all good. could shudder be 4wd related? or hicas?? i will locking hicas soon so that wont really worry me
also i can feel a massive loss in power think due to 4wd slippage
but example my mate owns a VR HSV GTS i used to kick the pants off him in a drag like 3-4 car lengths type thing now with rolling start (remove my traction advantage) me on 3k just before boost we are even now he only has 180rwkw and i should have 200+rwkw (zorst,filters and 14psi) any ideas??
also boost seems to be lagged more but thought might be cause i put silencer back into zorst (creating back pressure = lagging boost) full boost used to hit by 3500 now hits at 4000-4500rpm. will be fitting EBC on wednesday so hopefully should fix that
Sorry for long post
thanks peeps
RellikZephyr
https://www.sau.com.au/forums/topic/105628-shudders-when-turning-at-low-speed/
