mine are just put into various folders
starts of with 4 folders cars, senic, family and friends and macro
then they each have smaller folders that are the dates all are taken.
so if i go to a forest one day, all the photos will be in a folder named forest 1/2/06 which is in the senic folder
works for me :(
  • 4 years later...
  Pva_Glue said:
photos?
What programs do you guys use for organising your photos.
I have about 5 GB worth of photos that need to be organised.
I never delete Photos :whistling:
now its eveywhere unorganised.
can someone shine light on my photo collection with some good programs.
Thank you all
cheers
Joe
Hi I use Imatch it costs but its well worth it give the demo a try
http://www.photools.com/
Phill
Lightroom and Bridge are pretty much the same thing. They're awesome and powerful. You can set tags and search, give ratings and status updates on pics and lots more.
I have folders split into categories.
e.g.
car
___my evo
___your skyline
___eastern creek
___blah blah
people
___friends
___family
___model
________nik
________your mum
Landscape
____where
____where else
also have a folder called 'dates' for random stuff i haven't sorted.
  • 1 month later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
