Can anyone help me? i have a clicking noise on my r32 .. when ever i take off it clicks, change gears it clicks, turn a bend it clicks, gear down it clicks, even boost spools up quikly it will click under the load. the clicking sound is kinda like the sound if you got a pebble stuck in you tire and it clicks as it rolls over it.
i have no pebbles
i can also slightly feel it on the peddles. has anyone ever had this problem b4... if so please ease my pain..
thanks guys!
https://www.sau.com.au/forums/topic/105663-clicking-noise-driving-me-insane/
How about a description of WHAT causes it?
does it increase in frequency with speed (drivetrain) or rpm (engine)?
how does cornering affect it (suspension)
from your 'pebble on tyre', perhaps you should try rotating all the tyres individually (by hand?)...
EDIT: fixed spelling
Edited by ebola
I have had this problem (attributable to increase in speed) it occurs for me when going over 80km/h and then disappears about 100km/h
It was not engine related. Why the past tense well...
I did the following
Secured fron fog lamp leads
Secured inner guard after lower section removed
Got tyres pulled off rims to remove dirt balls the build up sometimes
A HOST of other things to ni avail
Then one day...it just went away...had me stumped, mechanic stumped
Fulcrum stumped...its the little gremlin, maybe I went fast enough that he finally f#cked off
i had a constant clicking sound
it was one of the vents in the aircon system not closing quite properly, and it'd keep trying forever
click-click-click-click-click-click-click-click-click-click-click-click-click-click-click
hmm. has it had a manuel conversion done?
ive had it where the dust cover on the back of the box had a dent in it. rubbed the tailshaft each revolution.
also check the tailshaft for ware. ie.centre bearing(midle bit) and the unis.
also stones can get behind the brake disk backing plate. similar sound
but i really need to know if it speeds up with the car/engine ctc
ive got the same thing. firstly it was a screw in my tyre. got some coilovers put in and then got the puncture fixed. noise is still there. only happens on certain types of road surfaces and whenever i turn right. it is also relative to speed too.
Its got nothing to do with engine... now that you mention CVs. my mums camrys CVs were about to go and the sound was similar. my clicking noise only comes when i take off, gear down and sometimes when i plank it and boost picks up quikly....it is definatly at my right rear wheel... it clicks alot going up my drive way because of the up hill.... i just changed the shocks but i had this problem b4 hand so its not them ... im so confused
Can you swap the drive shafts left-2-right? See if that causes the sound to come from the left. That would start pointing the finger at the CV joint (which is my guess, regardless).
I dont know if this helps but my car clicks whenever i turn the wheel cos my steering rack needs to be overhauled. The r32s steering racks bugger up pretty quick around the 100k mark. But id desnt sond like it comes from there all the time but.
Another thing is i have on my car is cos its a fourdoor the seat belt is pretty slack once its on(due to the sorter front door). The socket or whatever u want to call, it clicks everytime i move it clicks dunno why but it clicks, very annoying.
clearly im wasting my time :)
Ooooooooooooooo! What an angry frog :(
By the looks of this thread you haven't checked back in since you started it but if it makes you feel any better i to have an R32 with the exact same click noise from the right hand wheel as well!
I'm a mechanic and have been meaning to have a crack at tarcking this gremlin down but haven't had enough time to even start the car let alone fix things for months. I also have access to a skyline Guru so i might even ask him if he has struck it before and will try to keep everyone informed
On mine = when stationary engage the clutch for a brisk take off and straight away as if with the torsion applied to the rear a very quick "click,click" and also occasionally after a stong acceleration with a sudden off throttle, same thing.
Once i held the hand brake on and tried it = still there = rules that out
Possibly a CV but thats an awful big call when there are so many other things You'd check prior and without disassembling you car! also when ever i've had CV's clicking it does it all the time in many driving conditions.
I think a pair of chassis ears will be the go.
But my first port of call would be to really clean up the rear brake pads and apply brake grease to any contact surfaces and make sure they hve the shims they're supposed to!
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
