Front Pipe + Dump Pipe (Before/After Dyno Results) - 203rwkw Stock ECU/Turbo
Originally posted by EnricoPalazzo
Man wats up with ur ECU
your car is a freak
Congrats!! : )
I've said it before and I'll say it again.
I swear the 1995 ECU's are different, but I'll check when I get mine done.... One day.....
JiMiH - I wouldn't say the difference was massive, but it was noticable.
  • Replies 84
Benm - if you ever have a look at your ECU, let me know what the MEC number is on it.
The MEC number is located on a black sticker on the lid and the back of the ECU covers, and also stamped on the CPU itself.
It'll be something like MEC-R523 etc. The MEC number is the firmware version in the main CPU.
It'll be interesting to see what you have.
Unless you've got a chipped ECU, then that blows that idea out of the water ;)
J
Well I've got a 95 model and my A/F ratio was 10.5:1 before the SAFC tune, so either the ECU has been fiddled with or maybe your fuel pump is not flowing the best or down on press, either way good result, I only managed 188rwkw@12psi and that's with the SAFC, no dump or hiflow cat though do you think the dump is a worthwhile mod?
but look how straight his a/f graph is when on boost. A faulty fuel pump would have it all over the place and not that linear! Sum1 has tinkered with it for sure!
You're always a sceptic aren't you insasnt!
Good work there benm.. although to me it sounds like the A/F is running too nicely for it to be a non-modded ECU (in whatever way). Maybe not though, and it could be a '95 ECU difference if there is such a thing.
For some comparison i should have my '94 dynoed this weekend. I have a HKS dump pipe, front pipe to hiflow cat and straight thru 3" (Super Dragger II), and fairly similar setup with i/c, safc, pod, but now running an EBC.. I changed the oil the other week and should have put some new plugs in before it goes on the rollers (or at least gap checked/re-gapped) to give it peak performance. Will see what mine can get up to. Last was 177 but that was the previous owner on a different dyno without the EBC). Seems like a few are getting right up there to reaching 200rwkw without changing the turbo but of course everybody will argue dyno dynamics.
I'll post what I find out this weekend (with hopefully some people who know a lot more than i do!)
Anybody...Can u measure the A/F ratio via the SAFC ? I have an airflow % is that similar?? Can i work it out via some means?
predator666
we will see if u can beat me this weekend on he same dyno. Thats the only way u can really compare rwkw figures cause all dynos vary.
u need to get the signal from the oxygen sensor to be able to get the a/f ratio. The safc doesent get that sort of signal input i dont think, cant remember what wires i spliced into the ecu!
I see what Jay is getting @ here, & have always wondered about this possible '95 ECU difference? After all the Apexi PFC part # changes after late '94. I realise this is due to a number of changes (ignition amp being one of them) but just maybe........?
Actual dyno figures aside, it certainly is interesting how a number of '95 model GTS25t's have very good A/FR's with OEM ECU's!? And seem to make good power (rwkw) with the OEM ECU. Not all 95's do but I've now seen 5 or more that are "freaks".
Bugalug's car - ~204rwkw, stock ECU, perfect A/FR's throughout the rev range (12:1 peak power)
Benm - Well whadda ya' know! The same mod's as Bug's car - 203rwkw, stock ECU & impressive A/FR's given the norm' for a GTS25t (10.0 - 10.8-1)
rev210 - Very impressive 1/4 results! No doubt helped by a good use of basic mods & driver skill (low 60's for a 205) but none the less a high TS of 104mph. Wish you'd have put it on a known local DD dyno to see what the A/FR's were like rev! (prior to the S-AFC2).
There's more to add to this list but I can't recall names @ the moment? Some of the SDU '95 owners are among the list of outstanding OEM ECU results too.
It could be total coincidence that these "freaks" are '95 models? But I've yet to see a 93-94 GTS25t with a stock ECU running the show produce much better than high 10's - low 11's A/FR @ peak power.
its hard to measure of course once any sort of aftermarket thing goes in.. but i can pull some chip numbers out of my ECU - think my car build is 11/94 so could be an interesting one.
YAY - someone see's what I'm trying to say...... :D:/ :/
Well, when I get off my butt and take my car to a dyno I'll do a comparison cause I've got a 1993 and a 1995 ECU at home (I popped the tacho output on the 1995 :( , and got the 1993 to replace it).
That way I can do a direct back to back dyno run on the same dyno 5 minutes appart.
The 1993 ECU is MEC-R521 serial no., and the 1995 ECU is MEC-R523.
Stay tuned :D
My AFR's non-SAFC are around the 12's at best, for sure.
my ecu is a '522'.
What a rip off I only got the 94 ecu! Thats why my car is so slow! I knew it those bastards! That does it I'm putting the concrete in my boot tonight!
BTW I am pretty sure my R33 is making around 270HP @ the motor maybe a little less. Judging from the cars speed and my previous experiences.
before people ask me "how do I know my AFR's aren't lower?"
Look how much fricken timing I've run on it! Now with the S-afc sorting things I can't run as much if I want the leaner pastures. And I can lean quite alot without dropping below factory advance.
Originally posted by rev210
Further to my post about guesstimating my afr's I should have said my top end would be 9s and the low/mid range max of 12's (non-closed loop stuff).
how is it possible for u to guesstimate your a/f ratio's?? unless u are running behind the car smelling the exhaust fumes. :lol:
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
