Front Pipe + Dump Pipe (Before/After Dyno Results) - 203rwkw Stock ECU/Turbo
  • 1 year later...
  • Replies 84
Okay guys as promised here are the before/after results of some cheap maintenance + the different between a cat-back and a full exhaust. The graph is shown at the bottom.
Spec's:
BEFORE - Green line on the graph
1995 GTS-T Series II
FMIC (Micks Metalcrafts)
2 Stage Boost Controller (7/12 psi)
HKS Pod filter
3" Nismo cat-back
Stock ECU
Stock Turbo
96 RON Fuel
Motul Turbo Oil done 8,000km (Ouch!)
Results:
7psi = 168 rwkw
12psi = 192 rwkw
AFTER (3mths later) - Red line on the graph
HKS Pod filter
3" Nismo cat-back
Stock ECU
Stock Turbo
* 3" Custom 1 piece Front+Dump Pipe
* 3" Custom Hiflowed Cat
* 98 RON Fuel
* New Ryco Oil Filter
* New Ryco Fuel Filter
* Castrol Magnatec Oil done 2,000km
(Car has not been serviced by a mechanic for atleast 15,000km, Just been doing fluid changes and sheee purrrs)
Results:
7psi = 185 rwkw (Up 17rwkw)
12psi = 203 rwkw (Up 11rwkw)
Conclusion
Well as you can see some cheap maintenance and a proper full exhaust system can make quite abit of difference. The midrange power in my car is 500% better now that I have a proper full 3" exhaust. Some of the benefits I (as a driver) noticed after fitting the exhaust:
* Heaps better midrange power it almost feels like the Turbo is cutting in earlier
* Much more free flowing when you back off the gas it literally just rolls for ever, none of the sudden jerky-ness it just keels going
* No difference in the note/sound of the exhaust from the inside the car
I don't know how my car drove with just the stock standard Nissan exhaust as the previous owner had already fitted the 3" Nismo Cat-Back, but basically from a novice drivers point of view your exhaust is only as good as the weakest link and if you only have a standard front + dump pipe your absolutely kidding yourself. Go and spend the extra $750 like I did and you'll love it to bits.
I have no idea if the ECU has been re-mapped or has an addon-card. I've taken the kick panel off and everything appears to be stock, oem nissan stamp, no extra doobie-whackys etc. If you see me out and about ask me if you can see my ECU as no doubt you'll know what your looking for to work out if its stock or not coz I really have no idea.
I'm gonna keep throwing small amounts of money at this car (when I workout a new bank I can rob that isn't local) but keeping the Stock Turbo + ECU and really see what I can get out of it. Their have been HEAPS of people say that 200rwkw isn't possible from a stock ECU/Turbo well im going to get more out of this bitch you just watch me. (Hoping 210+)
I plan on changing the HKS Pod to an Apexi filter and also install the f/glass box I have and create an airduct from down on my front bar to feed the engine some much needed cold air. Maybe also 1 of those oil catch can thingy's and urmmm well I dunno i'll keep reading SAU to workout what else can be done.
If you have any suggestions throw em hear as i'd love to hear your comments.
Ben.
[MOVEIT]
well done!
try a cold air feed down low up to your filter if it makes that power with 12psi of
hot air you will notice the diff str8 away being able to push 13psi max n no pingn,
havent followed ur progress but have u thought of using 98 octane and
advancing your base timing couple degrees? cheaper then a power fc too. lol
what about?
water spray mist on cooler when pressure rises above 10psi? all ads up.
:P
This thread is 2yrs old and alot has changed since then the main thing being that the dyno used for this run appeared to record slightly higher than normal power.
  • 11 months later...
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
