You know, if anything an aftermarket core will have more pressure loss because of the much much longer tubing (ie 500-600mm!) it has to travel thru. I wouldnt be suprised if the stock one outflowed an aftermarket one. But the temperature drop would be second to none.
FMIC doesnt give power on its own really, it allows more power to be made by letting you turn up the boost safely especially in hotter weather.
Sorry completely disagree again. :P
Sure it is related to the overall size of the intercooler, but thats a long way from being the most critical aspect. The tube design, the number of tubes in the core, the end tank design all would play a much larger part then the tube length when it comes to working out the ability of an intercooler to flow.
I would bet any sum of money that my 600x300x65 front mounnt has way less pressure drop then the std intecooler. It would be in the vicinity of 2-4psi better :)
...i will add in an exagerated example. If you are trying to blow thru a straw, you will have a hard time blowing through it. You will get choked flow in that what you are trying to force throught it is more then physically possible. So you will get a large pressure difference from inlet to outlet.
Now change that little 6mm diam straw to a 15mm straw, or blow through 4 or 5 straws together, it wont matter if the straws are longer, they will flow more. The aftermarket cooler has a different qty of tubes and differently designed tubes.
Sorry, Busky, but i think what you have said is so wrong, it needs to nipped in the butt before it becomes fact thats thrown around...LOL then again you cold be right and me so wrong...but i hope thats not the case ;)
Well I edited my post but yeah as I mentioned before, the pressure drop across the stock intercooler was 1.5psi at 170rwkw, so its not as much as people make it out to be. It was actually less again when I used a thicker (80mm) S15 core.
Needless to say its no excuse not to get an FMIC. Its definitely worth it.
EDIT - To illustrate my point a while ago with my stockie intercooler (same size on the skylines I believe) I had a boost gauge pre and post intercooler. THe difference was only about 1.5psi at 6000rpm, when the car was making approx 170rwkw. Thats stuff all really...
So whats your car.AN S15? It could be that they are not as bad as the old R32. I was measuring the inlet manifold with an accurate MAP sensor, and with the std cooler it was about 0.65-0.70bar depending on time of say (night cold, day hot) With the new fron mount it went to 0.85-0.90bar, but closer to the 0.85 end of the scale. Again the ambient temp did alter it a bit.
So an an R32, is was an easy 2psi improvement over the std intercooler...then like you said i get whatever power improvement from the increase inboost, and my power will be more consistant over a hard drive as the intercooler is more effecient.
Its an S14 whose intercooler is 60mm thick. I swapped it for a 80mm S15 intercooler because they were a straight swap. Out of interest I did pressure drop tests on both of them.
Anyways I have a Blitz FMIC and I would recommend it to anyone. The time it takes for a stock intercooler to become heatshoaked is verrryy short indeed. Just drive around on a hot day keeping _off_ boost, put your hand on the intercooler and you'll almost burn yourself!!
ok from dump pipe to intercoolers... anyways 470 for a batmlb front and dump would probly be the price for ceramic coating which is worth while getting but for mild steel which is ok not so blingin'! though there 395 from memory...well worth it... also
with coolers it would highly depend on what cooler you have blitz coolers only drop 0.06bar i believe but a china dodgey brothers one might drop 0.1 bar my r32 runs about 0.85bar with a cat back and pod so the chances of me running 1 bar are very good when i add high flow cat front mount and a batmbl front and dump hmmm turbo blowing goodness!
If your battery was low on voltage and you noticed an improvement in power when driving its probably because the ignition drivers were struggling to do the job with the voltage that was available to them.
Id be inlcined to have your alternator checked as well! When your driving shouldnt it be the alternator that is giving you a a nice 13-13.5Volts???
I'm also going to be getting one of these dump pipes when they are next availaible and was wondering weather i should get the stainless steel or the mild with ceramic coating?
whats the difference gonna be?
Guys with the intercoolers it's pretty simple as 2 why u'd go a larger cooler. A 1.5 PSI pressure drop across an intercooler flowing enough air for 170RWKW is still pretty high. I guessing busky that ur running about 12 PSI of boost? A good intercooler should have about that pressure drop at about 20 PSI. Put simply the standard intercooler is more restrictive & while the aftermarket 1 may have a bit more lag (Piping length & size dependant also) it will cool the air a lot more once on the move. Cool air is more dense meaning more air in each cylinder on each stroke, which also means more fuel can be added = more power.
Think of it the same way as you would your exhaust system as far as the air flow is concerned. Just because the amount of air it holds is more doesn't mean it gets a bigger pressure drop. Its all about how big the holes are that the air has to get through.
Hope that clears things up a bit.
And personaly I'm going to buy a Split Dump off of BATMBL, while it may seem that for the money the gain isn't that great now, when u up the boost more when u up the boost more after changing the cooler & other bits, the gain will be even greater. Spend the money on the better system. It'll pay for itself in the long run.
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
