Hi all , there are soon to be some new Garrett T3 flanged integral gate exhaust housings in .63 and .82 a/r for the GT30R/GT3540R ranges . They are to be available in April 2006 but no details yet .
This will help those who want to use GT30R's and GT3540R's but without the external wastegate . The rumor is that the dump side will look something like the Fords XR6T's GT3540R housing .
More soon I hope , cheers A .
This has been in the spanners for well over 2 years now, it should have been done earlier, but GARRETT have been constantly changing cast manufacturers, thus the delay
As disco stated, late April/early May
The backorders on them are HUGGGGGGGGGGGGGEEE to say the least
Thanks
Tarek
RACESPEC
LOL , don't know ATM . The turbo is a long way off yet but with some recent research into GT3240's and some of Garrett's GT bush bearing turbos it seems there are 82mm GT40 compressors in 50 , 52 and 54 trims . I feel the 56T on Garretts GT3540R is a little big for the power or I should say torque I want so its a waste of turbine energy spinning something thats never going to achieve its potential . Far better to use the compressor wheel trim that suits my needs as it should be more responsive and increase turbine efficiency a bit . The $64 question is can the wheels be bought and is the back of the wheel the same as the BB version ie flat back or tulip shape and so on . Brett from GCG tells me they can drill/bore the centre hole if necessary so if the bush bearing shaft is smaller its not a problem . If I'm lucky and it bolts straight up I'm laughing .
Another thing to look into is this extrude hone process , the Americans say that noticable gains are had from extrude honing the turbine housings . This is not so much from a making the passages any larger but smoothing them out which aids the flow rate but not at the expense of gas speed . Its supposed to give a few more points of measurable turbine efficiency . Some of the turbo sellers will do this in the US at an extra cost so its an option if you buy from them . It could be done here but the set up cost is not cheap and I have seen the result of just a bit (lot) too much taken out .
I was told about these C117 compressors about 18 months ago , like the later GT40R has , and there is supposed to be new turbine designs on the way but when is anyones guess - they may already be out there in truck turbo's .
So I can wait and when the car eventuates the goodies get stashed away as turbo technology marches on and it all comes together .
I hope I can resist the temptation to play with the RB20 - maybe just an rb25 turbine housing - see I'm hopless !
Cheers A .
For Cubes hot off the press , Brett tells me there is an 82mm 52 trim BCCW18C compressor (59.1mm inducer) available . Just have to figure how difficult it is to fit and if HKS's idea of using the .60 a/r TO4S cover for 50 and 54 trim 82mm wheels is the go .
The amusing part is that with these GT40 compressors the inducer sizes are as follows .
50T = 58mm
52T = 59.1mm
54T = 60.3mm
56T = 61.4mm
So only 3.4mm the difference 50 to 56T though its supposed to make a very real difference in the way they load up the turbine particularly initially . As I have mentioned before the difference between a 52 and 56T GT30R is 500 rpm .
Cheers A .
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
