i just got a chipped worked ecu for my r32
the ecu came from an rb20det c33 laurel
now for some reason when plugged in the car just keeps turning over and doesnt do much else....
then we tried it in my mates r32....did the same thing....but thats when we noticed!!
the fuel pump wasnt turning on!!
whats the deal....is the c33 laurel pinout different to the r32????????
if so....does anyone know where i need to re route the fuel pump to??
any ideas???
Edited by heyhey!
https://www.sau.com.au/forums/topic/105716-experts-needed-difficult-one/
You can run your fuel pump directly off an ignition source in a pinch until you can find the right pinout diagram and then rewire it correctly.
This assumes that the rest of the pins are the same, as cranking the engine has nothing to do with the ecu.
HArd wiring the fuel pump is a bad idea. If you have a accident and the fuel line gets damaged/broken the fuel pump will continue to pump fuel out of the broken fuel line while the ignition is on.
With the original ECU and aftermarket ECU's the computer will shut down the fuel pump when the engine stops sending the an ignition signals i.e. when the engine stops.
ASH
you can hard wire the pump but you will need a special relay... the use it on gas conversions . it allows the system to prime when the key is turned on, runs for two secs then shut off, then when ya crack or car is runnin the relay is locked on( uses a tacho signal). when the motor stops the relay unlocks... and stops pumpin fuel. relay cost about 30-40 bucks...... i had to use it on a conversion on one of my other cars.... i hope this helps
i only hardwired the pump for a second to see if it was the only plug wrong on the ecu....but it still wouldnt run...so id say there is many many plugs out of whack...
so if anyone has a genuine laurel pinout diagram...or even a cefy pinout diagram...
that would help!!
I have a Cefiro (presume the same RB20DET as the Laurel) and I can tell you that the R32 uses a more recent version of the RB20DET than the A31 (and possibly the C33). I know the wiring looms arent compatible because my car runs all the older type of plugs (square) where as the R32 runs the rounder plugs etc. I think my ignition system is the same as the R31 RB20DET. So it runs a much older ECU etc. perhaps this is why yours isnt working because it may be expecting different voltages etc
JK
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
