i just got a chipped worked ecu for my r32
the ecu came from an rb20det c33 laurel
now for some reason when plugged in the car just keeps turning over and doesnt do much else....
then we tried it in my mates r32....did the same thing....but thats when we noticed!!
the fuel pump wasnt turning on!!
whats the deal....is the c33 laurel pinout different to the r32????????
if so....does anyone know where i need to re route the fuel pump to??
any ideas???
Edited by heyhey!
https://www.sau.com.au/forums/topic/105716-experts-needed-difficult-one/
You can run your fuel pump directly off an ignition source in a pinch until you can find the right pinout diagram and then rewire it correctly.
This assumes that the rest of the pins are the same, as cranking the engine has nothing to do with the ecu.
HArd wiring the fuel pump is a bad idea. If you have a accident and the fuel line gets damaged/broken the fuel pump will continue to pump fuel out of the broken fuel line while the ignition is on.
With the original ECU and aftermarket ECU's the computer will shut down the fuel pump when the engine stops sending the an ignition signals i.e. when the engine stops.
ASH
you can hard wire the pump but you will need a special relay... the use it on gas conversions . it allows the system to prime when the key is turned on, runs for two secs then shut off, then when ya crack or car is runnin the relay is locked on( uses a tacho signal). when the motor stops the relay unlocks... and stops pumpin fuel. relay cost about 30-40 bucks...... i had to use it on a conversion on one of my other cars.... i hope this helps
i only hardwired the pump for a second to see if it was the only plug wrong on the ecu....but it still wouldnt run...so id say there is many many plugs out of whack...
so if anyone has a genuine laurel pinout diagram...or even a cefy pinout diagram...
that would help!!
I have a Cefiro (presume the same RB20DET as the Laurel) and I can tell you that the R32 uses a more recent version of the RB20DET than the A31 (and possibly the C33). I know the wiring looms arent compatible because my car runs all the older type of plugs (square) where as the R32 runs the rounder plugs etc. I think my ignition system is the same as the R31 RB20DET. So it runs a much older ECU etc. perhaps this is why yours isnt working because it may be expecting different voltages etc
JK
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
