im pretty ure that it is hooked up rite its just bolt on and i put the vaccum on the hose was to big so i slid the new hose in the old 1 maybe it didnt seal??? i will try and fit it better ! thanks for the help i will let u know how i go
https://www.sau.com.au/forums/topic/105723-hks-ssq/#findComment-1948271
no good just replaced all the vacuum hose wlth a hole new line that fits real good and its still not blowin off, its just flutterin through the pod?? its bolted straight on to the stock cooler piping with a gasket in between.. msut need more boost maybe???
https://www.sau.com.au/forums/topic/105723-hks-ssq/#findComment-1948511
Try loosen the nut at the back of the bov a bit.
https://www.sau.com.au/forums/topic/105723-hks-ssq/#findComment-1949534
  • 1 year later...
    • Too much work, but guess I will have to
    • qld plates “GTR R34” for sale $5500 (listed else where)
    • Or, just take PS pump off and inspect? Does no-one do this any more?
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
