thanks for that guys, im looking at skylines at the moment, though im just sorting through all the shit cars, there are so many dogs out there. Trying to find one half decent b4 i look seriously at it. will def pm/ring when im going to look into more detail at the car!
Cheers, Tyson
https://www.sau.com.au/forums/topic/105732-32-help/#findComment-1953395
Check the undercarriage for dodgies.. be careful of ones where the paint looks *too* good, as a cheap job may look good now, but in 6-12 months start bubbling up as more than likely it will be a cheap job (some dealers nearly respray all stock). It will be near 15 years old, not many cars have immaculate paint jobs by then.
Otherwise just take it for a drive, check for clunks, floaty steering, make sure the brakes pull it up well. Check for crunches in the gearbox, clutch engages freely, even tyre wear, and oil leaks, particularly under the engine (rb20's love to leak when old - and usually its a bitch to fix).
Oh, pull off some of the intercooler piping (or AFM), and check for accessive oil in there. If there is any more than a tiny amount, definitely don't buy it.
https://www.sau.com.au/forums/topic/105732-32-help/#findComment-1954442
You can check that pipe.. or main intake pipe that goes to manifold.. Basically if there is a *lot* of oil in there (as in you can see it dripping off your fingers), there is oil from the sump blowing past the piston rings during each combustion stroke. Meaning the piston rings are worn.
This pretty much means there isn't too much life left in the motor as it'll only get worse and worse until something gives way.
It can also mean that the turbo is going, letting oil into the system -- again whilst not as bad as piston rings, probably not a great thing.
Anyhow, that is my explanation... :)
https://www.sau.com.au/forums/topic/105732-32-help/#findComment-1959522
    • Yeah, sort of blurring two different things together, aren't we? I just meant O2 feedback closed loop. I used to have a 0-1V LCD meter on my dash, wired directly to the O2 sensor signal. So you could easily see what it was doing. Normal running it would flick back and forth nicely. Slow down to an idle and it would keep flicking, as the ECU tried to servo to maintain stoich, but it would slow down as each swing happened until it would stay at one end of the scale. As I said above, the sensor heater is not enough to keep it hot enough when there is also little heat in the exhaust flow. Give it a blip and it would start swinging again, then peter out again. Meanwhile, idle speed control would run just fine, because unrelated.
    • It's not even O2 feedback, it's just simply when the ECU sees the closed TPS signal for whatever reason the idle will start steadily dropping until the engine dies. With the TPS adjusted to not trigger closed TPS it will idle at some ridiculously high RPM and something like 6 degrees of timing. In the absence of getting eyes on it personally and a lot of quality time doing diagnostics I couldn't tell you what the real problem was but it was interesting nonetheless
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
    • Great work Duncan, any events local you will give it a test once all done?
