guys i have a major prob...jst got my car bak from the kanic, ran sweer 4 bout 2 weeks. now she idles rough, accasionally puffs oil smoke,and wen gets boosted past 7psi, it throws u over the steering wheel...once u get revs up off boost its ok, if u rev 2 high or boost it, the catch can nearly explodes with overflowing oil.....i had sum work dun described below:
xtr high flowed turbo,zorst, hybrid cooler,850cc injectors,haltech ecu,550hp pump,twin plate clutch,etc.. u thnk possible lean out ending my rings? HELP!!!!!
https://www.sau.com.au/forums/topic/105733-cant-boost-past-7psi/
il do a comp test 2 day.. ive been meaning to but my lazy ass couldnt be fudged taking all that piping crap off...wat a bitch of a job just to do a plug ay.. its been tuned for 300rwkw so he says, it was leaving holden r8 s for dead, now im lucky if i can beat a vw beetle off the lights!
Sounds like rings to me  :wub:
More than one... you might have the record of 5 by the sound of it
i just picked up a seal kit, ring set and 1.6mm head gasket. at a total price of $845...... gotta love aftermarket nissan gear...lol i hope ur rite r31nismoid, i cant really afford pistons on top of that
Ringlands of the piston will most likely be cactus I'm afraid.
Unless your motor has lots and lots of kms on it the factory nissan rings will last quite alot longer without losing compression.
You say the engine has been 'tuned' to 300rwkw. Do you have a dyno readout with the AFR's, RB25's need to run on the rich side of 12 to be save at higher boost due to having some decent compression ?
The other thing is that a 550hp fuel pump (I'm guessing walbro) is a tad small for 300rwkw given drivetrain losses. That sails very close to the wind. If you had a partially blocked fuel filter you could lean the motor out. At 412rwhp or 307rwkw figure that pump maxes out assuming it's going to even get 550hp worth of fuel in at the fuel pressure you are running.
Sorry mate. Sounds like rebuild time. At least you can put some forgies in there to handle the power better next time.
the motor has dun 175,000klms.... please say just the rings....
Thats alot of kms. However, the shear amount of oil going in to the catch can, the fact that the fuel pump is smallish, there wasn't a gradual increase in oil catch and it showers everyone in oil if you floor it means busted piston.
It's all over my friend. A compression test will show you the money very quickly. If you don't have a guage a cheap one can be bought for $30 from somewhere like supercheap auto.
have to agree totally with rev, its either rings gone (DEFINITELY more than 1), ringlands or the pistons themselves. If it were just a single ring it would take a little while to fill the catch can...
rebuild time, but definitely a comp test and possiblly a leak down will show the true colours of your problem!!!
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
