Seeing if any of you have had this problem before. I found on my R34 that the windows were not sliding up evenly. A friend of mine said that all it was was the rubber guides drying out and that I should spray a little silicon spray on the tracks and the top guide.
I did this, but now there is Silicon spray smeared all over the inside (tinted) and outside of the glass, as it has also soaked into the bit at the bottom that cleans the water from the windows.
HOW do I get smear free windows again? What can I use to clean it?? :P
Any help appreciated.
https://www.sau.com.au/forums/topic/105746-help-with-silicon-spray/
Yeah, the window runs like brand new again. The drive motor sounds like it is running much smoother now too.
I have also been told metho will clean it up, so I will give it that a shot too.
Cheers
get some window cleaning spray, should take it right off, or try some turps,
did it fix the window problem though?
Sounds like you sprayed too much on.  Do you think?
Yeah, very easy to get carried away when you are trying to get the window to wind up smoothly again.
as long as this dosn't remove the tint!
I spoke with a Tint friend of mine and he said metho is fine as it doesn't contain a certain chemical that Windex Window Cleaner has. He said never to use window cleaner as it has this chemical (I forget the name) that will kill your tint sooner or later.
na, a few times might not kill the tint,, but it will damage it over time, and bye bye tint waranty,,,
just make sure u don't use on the inside of the windows (where the tint is)
the rest of ur car probably has factory tinted glass ya? cleaning them with windex isn't a problem,,
i think its ammonia or something like that , makes the tint go that gross purple colour,,
Afro, you never seem to amaze me with your wealth of knowledge!!!!
Ammonia....that's it. Nice to hear from you again!!! :P
It will only send the old style tint purple. It used a vegetable dye in its formulation as opposed to metalic particles used in current window tints. If it turns it purple - its going to go purple all by itself from sun exposure. :D
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
