When i had mine tuned it did feel a like the power came on alot smoother and according to the dyno sheet i have it was getting alot better air/fuel mixtures and it also did yeild a decent power increase i think it was like 5 - 7 kw though i am not 100% sure.
The main reason i got my SAFC II was because with the few bolt-on mods i had the goold old ecu started doings it typical nissan rich and retard...
In saying that though mine has gone stupid its almost like its lost its settings maybe the connecting is loose who knows but it has gone back to being very rich. When i get a moment i will take it back to a new tuner to get checked out.
My car is sporting one. I found that it partially fixed the missing/flat spot problems through the high rev range and increased power due to the alteration of the previous very rich air/fuel ratios (at that stage running 12 psi with aftermarket intercooler, exhaust etc – my standard R33 computer going into super rich air/fuel ratio mode). Although I feel the missing problem was a combination both the rich air/fuel ratios and faulty coil packs (now they are painted in a pretty blue heat resistant paint and work like a dream).
I wouldn’t be surprised if I gained at least 15rwkw after getting the SAFC tuned, and the power delivery was much smoother as Leech has said above. As I picked mine up second hand for a relativity cheap price it has been a very good value for money modification providing both a good increase in power and power delivery. Hope that helps :)
EDIT: Actually from what I remember (ive got a bad memory though :P ) the dyno run before it was tuned was getting close to 190rwkw (somewhere in the high 180’s at least) and now after the tune getting 210rwkw. Quite a large increase in power…
Edited by nismo_au
Alittle bit off topic but does anyone know if the VAFC and SAFC are anydifferent besides the VAFC having to a control for Vtec. And could the VAFC control VCT on a rb25??
Just wondering cos i've been offered a really cheap brand new Apexi item, but I can only get 1 and not a whole bunch.
Check the VAFC application charts on the apexi website (www.apexi.com). I think you will find they will work with Honda vehicles only. They are very specific about only using it with cars on that list “Do not under any circumstance use this product for any car application other than on the applicable vehicles”. Stick with the SAFC eh? :rofl:
I just ordered one then. Got it for $300 plus delivery of $60. Thanks for the replies. Now I only have to worry about who im gonna get to tune it. Any suggestions :(
Pete at Autotech in fyshwick is the man you want to see, he tuned my SAFC, A/F ratios are a bit healthier and i gained 0.6 rwkw to boot
that sounds pretty shit to me... though i guess like most things it depends on existing mod's, engine size, how much you strap it.
When my car was bog stock i was getting like 480 - 490 around town. Since putting the few mods i have on and increasing power i am now at around 450ish maybe 470 on the odd occasion.
I can vouge for that considering i was dumb enough to stand like 10 meters from it last dyno day and get absolutly covered in shit :)
Im yet to find someone to beat me for the sheer amount of black crap on the back of their car :wub: I wash it and its filthy again within 1 day though :D
I put an old school SAFC in my car a few weeks ago (push button type).
My car was previously running 187rwkw with the AFRs sitting at around the 13 mark (pretty dangerous).
After the SAFC install and tune the car put out 206.6rwkw, the AFRs went down to 12 and the powercurve was alot smoother.
Worth the 360 your going to pay IMO.
Then again, different cars get different results.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
