i am really surprised stel that your car was running leaner rather than richer...  every line i know that just has boltons it richens up like no tomorrow did you have a bigger turbo or something ???
Standard turbo at the moment.
The car may have had some work done to it before i bought it and was brought back to basically standard, when we installed the SAFC the wires were already cut for an SAFC. I know the guy that owned the car before me so i might give him a call and ask him.
I was impressed with the result myself....
welcome to the world of skylines and fuel consumption, I can get 400k's if i realy realy watch my foot, but normaly 300 mark.
LOL. It is still a step up from my old car. 250km to a 65litre tank. And thats if I was trying to drive econimically.
Here's a link to the Blitz R-Fit. I still haven't had any feedback from anyone using it as yet. It looks pretty similar in features to the SAFC. However I do know a guy with a 180 that is about to get his installed and tuned so I'll let you guys know how it goes.
http://www.blitz-performance.com/Blitz_RFIT.htm
Just bought a second hand SAFC2 yesterday, pending delivery.
Been searching for ages, finally found one for sale before the rest noticed :D They're pretty sort after, everyone wants one but doesnt wanna spend the $400+ for a brand newie.
  • 7 months later...
Sorry to dig up a really old thread but wanted to ask a few questions.
I managed to score myself a black SAFC2 from a guy on another forum, and it almost time to get it tuned somewhere. I am going to install it myself but wondering where fellow skyliners with SAFC's will recommend.
So for those of you who do have an SAFC, who installed it and how much was the install? Did you get dyno runs before and after or just afterwards?
I installed it myself, dead easy really.
Then took it to Ben at intune to get the tune done. He dyno'd it before and after, gained like 10kw accross the rev range and the beast uses much less fuel!
Very good results! Im considering this or saving more money and gettin a PowerFC dunno whether its worth it though
How much was the tuning of it Justin? I rang ESP and Trojan last week and both gave me around the same sort of price for install and tune. I have been recommeneded Autotech but they quoted me an outrageously high price for install tuning of it.
I have since decided to install myself, so I just want a tune done now.
Also does anyone know what dyno Trojan uses?
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
