I did a search but couldnt find info directly relating to this (probably because most people here run a PFC and therefore need to run an intake pipe and pod to accomodate the AFM). Im going to be running a LinkPlus and a large T4 sized compressor on a top mount manifold. Im debating whether or not to spend the extra cash and get a custom intake pipe made up and fit my HKS filter or simply leave the turbo without an air feed and mesh the air intake to protect the compressor wheel.
Most Japanese drag and Drift cars ive seen dont run pod/panel filters and simply leave their turbo's naked. I want to do this aswell for the sake of cost reduction expect 'hose-clamp' some mesh to protect the comp wheel.
Is this a good option or shall I get my HKS mushroom filter on there?
Edited by DRFT 14
https://www.sau.com.au/forums/topic/105760-run-intake-and-pod-or-mesh-turbo/
What about routing a pipe from the front bumper and into the engine bay and sitting it close to the turbo? Wouldnt that be a better option? Its seems aparent that a 'naked' compressor would suck air in a lot more freely as opposed to sucking through a filter. Wouldnt this alone make the compressor wheel spin alot faster and earlier and therefore reducing turbo lag and increasing power?
Sydneykid, im in NZ :P
Edited by DRFT 14
So what your saying is, even though I live in a generally dust/sand free place like Auckland City (or any such place), running a meshed turbo will cause damage to the compressor? Im not sure to be honest. It seems to me that unless im using the car as an offroader (which im not :P), then the turbo should be pretty safe?
Edited by DRFT 14
"pretty safe" to me is not GOOD enough IMO,
Filter is for peace of MIND, and wont be much diffrent in performance wise,
If u be able to make CAI, u only draw cool air in, its way better than being nake and sucking hot air from the engine.
or rain can easily get washed over the engine if you have a small gap in the bonnet..
or even one dusty road.. or just dust in the air generally..
big risk to be taking if you've obviously spent some money on the engine setup..
I always like going back to the MINES GTR thing.
ridiculously fast, has stock air box with custom intake.
so it uses a panel filter of all things..
and I think it still has stock intake pipe rom Air box to turbos too.
So why isn't it good enough for you?
So what your saying is, even though I live in a generally dust/sand free place like Auckland City (or any such place), running a meshed turbo will cause damage to the compressor? Im not sure to be honest. It seems to me that unless im using the car as an offroader (which im not :wub:), then the turbo should be pretty safe?
My car only ever gets driven in the city, You should see all the crap on the filter! I hate to think of all that junk in my bores
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
