Im having trouble installing the 2 point imobilizer into my r32. The imobilizer is built into the Black Widow alarm system (model BW10000). The instuctions say that there are 4 wires which are used for the imobilizer (2 for each point of imobilization). My understanding is that, i cut the wire in the car which i want to imobilize (eg ignition) and attach a imobilizer wire to each side of the wire (eg ignition) i just cut. After i had done this i tested it, however the ignition did not have power. i just wanted to know if what im doin is correct? help will be appreciated. thanks dean
https://www.sau.com.au/forums/topic/105766-installing-a-2-point-imobilizer/
  • 1 month later...
Easy fix.
The 2 recommended points to cut into are the starter motor wire from the ignition barrel and the fuel pump power wire.
This way your ignition is left untouched and thecar is still rendered useless in armed mode.
I've included a diagram of how to get to the starter motor wire, apply the same to the fuel pump wire. Reply if you still have any questions.
Hi arh32,
This is most likely going to sound harsh, but i mean it with the best intentions.
If you are not sure what you are doing take it to an authorised installer and have them put it in. An Alarm is only as good as it's instalation. If you were to follow the diagram posted on here it would take a thief about a millisecond to steal your car. Thieves target certain cars, and they know the wiring systems and what they look like, adding this type of in line immobiliser while effective against the amatuer would be no match for someone who has stolen one before.
Just read through the forums to see how many other people are now trying to recover a car because they saved " a few bucks" putting it in.
You would also find that a simple starter and fuel pump cut as described here will not be compatible with a turbo timer, so if you have one, you will have to sit in the car, or stand next to it waiting for it to finish before you can arm your engine immobiliser. Otherwise your car will efeectively run out of fuel each time, potentially causing damage to your injectors or fuel system.
Beleive me I have spent the best part of 10 years fixing up exactly what you are describing.
Now, it is not all bad, the BW10000 is an excellent alarm, i wouldnt have told the entire planet on a forum you have one, but they are excellent alarm. They do actually have 3 point immobilisation, 2 built into the box and one external.
It is possible and very achievable to have all three immobilisers hooked up and connected with a turbo timer and it all to work correctly. It just requires more wiring.
If installed correctly the turbo timer will not pose a security risk to your car either.
I cant stress enough how vitally important the instalation is.
Good luck with it.
Regards
Pj
im sorry but i have to mention this
i loath coloured wiring alarms
it just helps me disconect them ( Im a Auto Elec)
if you want a decent alarm go with something with all black wiring and has stickers on the loom that you remove
making it hard to identify wiring
but as mentioned before it all comes down to the install
cheap & dodgy install = stolen car
someone who takes time to fit alarm and immobilse circuits that cant be bypassed with a screw driver or length of wire = one happy customer with there car still
just my two cents
Easy fix.
I think there must be something wrong with the alarm because this is similar to how i installed it. (i understand that if a theif saw this under the dash he could just connect them back together. I have connected each side at two totally different areas in the car). Ive used the multimeter to see if there is a circuit by arming and disarming the alarm while the multimeter is connected to each side of the imobiliser but it doesnt seem to be picking up a circuit when disarmed.
I could actually tell him the colors as well ( I won't) next one I work on I'll take a few pics to share with you two. see if we do alarms the same way.
I dont think telling me the colours is going to help me as it is all black wiring!
Ok, check this: where you made the join on the original wires, take the two wires which go to the alarm module and use the continuity check on you multimeter. If you don't get a staight circiut when in the disarmed mode you may have crossed the pairs. Refer to attached diagram.
One last question, is this the Shadow alarm from Jaycar Electronics???
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
