Im having trouble installing the 2 point imobilizer into my r32. The imobilizer is built into the Black Widow alarm system (model BW10000). The instuctions say that there are 4 wires which are used for the imobilizer (2 for each point of imobilization). My understanding is that, i cut the wire in the car which i want to imobilize (eg ignition) and attach a imobilizer wire to each side of the wire (eg ignition) i just cut. After i had done this i tested it, however the ignition did not have power. i just wanted to know if what im doin is correct? help will be appreciated. thanks dean
https://www.sau.com.au/forums/topic/105766-installing-a-2-point-imobilizer/
  • 1 month later...
Easy fix.
The 2 recommended points to cut into are the starter motor wire from the ignition barrel and the fuel pump power wire.
This way your ignition is left untouched and thecar is still rendered useless in armed mode.
I've included a diagram of how to get to the starter motor wire, apply the same to the fuel pump wire. Reply if you still have any questions.
Hi arh32,
This is most likely going to sound harsh, but i mean it with the best intentions.
If you are not sure what you are doing take it to an authorised installer and have them put it in. An Alarm is only as good as it's instalation. If you were to follow the diagram posted on here it would take a thief about a millisecond to steal your car. Thieves target certain cars, and they know the wiring systems and what they look like, adding this type of in line immobiliser while effective against the amatuer would be no match for someone who has stolen one before.
Just read through the forums to see how many other people are now trying to recover a car because they saved " a few bucks" putting it in.
You would also find that a simple starter and fuel pump cut as described here will not be compatible with a turbo timer, so if you have one, you will have to sit in the car, or stand next to it waiting for it to finish before you can arm your engine immobiliser. Otherwise your car will efeectively run out of fuel each time, potentially causing damage to your injectors or fuel system.
Beleive me I have spent the best part of 10 years fixing up exactly what you are describing.
Now, it is not all bad, the BW10000 is an excellent alarm, i wouldnt have told the entire planet on a forum you have one, but they are excellent alarm. They do actually have 3 point immobilisation, 2 built into the box and one external.
It is possible and very achievable to have all three immobilisers hooked up and connected with a turbo timer and it all to work correctly. It just requires more wiring.
If installed correctly the turbo timer will not pose a security risk to your car either.
I cant stress enough how vitally important the instalation is.
Good luck with it.
Regards
Pj
im sorry but i have to mention this
i loath coloured wiring alarms
it just helps me disconect them ( Im a Auto Elec)
if you want a decent alarm go with something with all black wiring and has stickers on the loom that you remove
making it hard to identify wiring
but as mentioned before it all comes down to the install
cheap & dodgy install = stolen car
someone who takes time to fit alarm and immobilse circuits that cant be bypassed with a screw driver or length of wire = one happy customer with there car still
just my two cents
Easy fix.
I think there must be something wrong with the alarm because this is similar to how i installed it. (i understand that if a theif saw this under the dash he could just connect them back together. I have connected each side at two totally different areas in the car). Ive used the multimeter to see if there is a circuit by arming and disarming the alarm while the multimeter is connected to each side of the imobiliser but it doesnt seem to be picking up a circuit when disarmed.
I could actually tell him the colors as well ( I won't) next one I work on I'll take a few pics to share with you two. see if we do alarms the same way.
I dont think telling me the colours is going to help me as it is all black wiring!
Ok, check this: where you made the join on the original wires, take the two wires which go to the alarm module and use the continuity check on you multimeter. If you don't get a staight circiut when in the disarmed mode you may have crossed the pairs. Refer to attached diagram.
One last question, is this the Shadow alarm from Jaycar Electronics???
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
