Ok this is a curly one for you NSW and ACT lads....
As some of you know, I'm now living the quiet life in little old Adelaide, with hardly a problem in the world..... no riots, and no cop trouble! life is sweet!!!
ok I digress....
recently I had a speeding fine from, of all places, the ACT.... having recieved it via my NSW address, I was confused as to how this happened?
never having driven my GTR in the ACT.... and for the fact that I was in LA at the time, and the car was in the lockup garage in South OZ....
on ringing the ACT traffic board they tell me it is deff. the right plate.... so I ask for the pic!
pic comes back.... GTR-260 on NSW plates but instead of my black on white plate... its a dark blue or black plate with white writting!
hmmm....
anyone know another metalic grey GTR with either these plates or very very similar :rofl:
ciaooooo
https://www.sau.com.au/forums/topic/105814-anyone-know-who-gtr-260-is/
lol
could it be GTR26C???
and are your wheels the same type?
did you ask them what colour the plates r? if they are a diff colour ask the rta how 2 of the same plates got issued.. and that your more than welcome to present them..
also... u have proof the car was there the time of the incident?
crazed truckers! hmmm.... saw a few of them in my mamoth road trip...cairns-sydney-cairns in a BMW X5.... no I haven't jumped ship with merli ;)
so does anyone know a car with similar plates? the ACT say that they tried all the combos and beleive that it is me.... :P
anyhow they are not going to fine me, but if this happens in the future???
Ben just admit it was you. i cant belive you went to all this effort of painting your numberplates, and changing your wheels, and moving your car to another state and conconting this BS story about you being OS. just pay the fine!
haha, you bad man.
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
