have just had a dump pipe and a 3 inch front pipe installed and now i have a the reve range on idle going up and down around 200 revs. should i reset my computer or something????? anyone else had this????
Have you givn it a good thrashing now u have the new pipe? cos it will boost higher, and quiker. also, check your vacuum lines, cos i had a prob like that, turned out it was a vacuum leak. it would idle up and down wether it was cold or hot. and sometimes stall at the traffic lights.
By the way with a dump pipe should i notice more power gains, i have a full 3" system (inc frontpipe), and have a split dump coming this week.....i heard response is better, cant wait
depends on ur setup. a factory pipe will flow up to 250kw ish. bigger turbo, higher boost etc, and you will notice power losses. remember. flow=power=burnout.
resetting the computer allows the ecu to leanr a new power curve. generally if you have a stock computer you should reset it after every new upgrade
kryostaisis has a good point... after every mod u do, the engine will run and react differently, needing different timing and fuel requirements. resetting the ecu lets it "re learn" the motor to get the best out of it. if you get wat i mean...
