Hey guys,
Today I had the car started and idling for a while and I noticed condensation in the pipes to the oil catch can (I have clear hoses). I am a little worried as it has never happened before.
I opened the oil cap on the rocker cover and had a look but the oil was fine, doesn't seem to be any coolant or milky oil from what I can see. I also checked oil on the dipstick which was also fine.
So does anyone know what it means when there's condensation in your oil catch can hoses? :(
https://www.sau.com.au/forums/topic/105827-condensation-in-oil-catch-can-pipes/
Hey guys,
u probly just had a dewing cold nite. if it was something else youd know pretty damn quik... lacking power? blowing smoke? check radiator. any oil in it?
Nah mate, I just started it then, the weather wasn't too hot or cold. But it was a "cold start".
The car isnt blowing any smoke (at least I don't think) and isnt lacking any power. And the coolant is very clear, definately not contaminated!
keep driving it.. dont stress 2 bad, just keep an eye on water temp and oil pressure.. if ur driving at say 3000rpm and ur factory oil pressure guage is below half way, u need oil like straight away
My oil level is perfect and my stock oil pressure guage doesnt work properly so no point looking at that. :(
hmm that could b a problem...id b getting it fixed dude, last thing u want is a full catch can, empty sump, and not knowing it....
Hey guys... i always get water in my catch can...my mechanic says this is caused by condensation and only worry if i get oil in there.
Can anyone confirm this ?
Cheers
Lenno
hi
my bike is a ducati 900ss it has a glass window in the engine side cover to check oil level, when i do short runs to work only and no long runs where the engine gets to fully heat up I get a white milky sludge in the window and it makes it hard too see the oil level but give it a long run of over 100kms and the window clears up so condensation inside petrol engines is very common especially if you only do short runs.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
