Hey people,
I am new to this. So please bear with me. I just recently bought my baby and she has now got a mind of her own.
Its a GTST S2. When I start it, she goes ok but when I stop at lights and idiling, it revs up and down by itself. Can anyone give me an idea of what this could be. Hopefully, its nothing major.
Cheers
Hey people,
Cheers
sounds like uv blown off a vacuum hose, happeds all the time. look under the bonnet for a hose off ur manifold, and put it back on... the old nissan factory hoses are shit. wen they get hot and get sum pressure behind em, they blow off
Cheers for that. I feel like a dumb arse but I really want to learn about my car and how to care for her right.
dnt feel dumb, no one knows everythn! hey are u from campbellton area?
Nah. Brisbane.
how to care for an rb motor...hmmm haha... DONT thrash it, always check oil and water(if either of these gets low for a long period, temps go up, motor goes bye bye) and if ur guna keep it factory, dnt do burnouts... the diffs and uni joint dnt last too long
covered a few million times, try
checkin for leaks in intercooler pipeworking
check airflow meter fitting and plug
try ecu reset
You forgot to mention the 2 million times that it could be the AAV, or the TPS.
i had this problem when i had a leak in my radiator hose due to having a thermofan with a thermostat put in the top of the hose at the top of the radiator. air in the system is baaaaaddd
DAMN. Hope its not that.
Yeh RB engines and idling its a pain. Mine has a mind of its own. I was driving today everything was fine idling good and the im at the lights and my idle decides to go from normal to 1,000rpm. This happens at all the traffic lights all the way to my girlfreinds house. Then when i drive to the restaurant for a little while it drives fine then it starts to idle at the same place at every traffic light. OK park the car go have dinner at a restaurant come back drive it all is ok idling at normal speed?? what da?? it use to do it before but only for a little while then id rev it and it would go back down now it wont go down if i did it. I did the ecu reset all was good till today. tps is fine. before i go cleaning aav and air flow metre anything else u guys think it could be. its just strange as it comes and goes. i might do the ecu reset again think this will help???
Edited by LatinR33
