I saw a preview on A Current Affair that will air on wednesday 15th feb about how everyone should contest speeding fines. The police have apparently not been looking after their gear and everyone can now get off... bla bla bla. I am sure it will be spectacularised and not the entire truth but may be worth watching.
https://www.sau.com.au/forums/topic/105857-a-current-affair-tonight-15th-630pm/
hahahaha you me and everyone else with an import!!!
TMU  <_<
i been good for the last 9 months.. only cause i havent driven it thanks to engine conversion >:P
hope to be driving it again in a couple weeks :S that one point isnt gunna last i can see it now.. i better pull out the push bike and start using it to get some practice
Edited by Wazz
i think its a repeat story of something they had a while ago about a certain type of radar gun being faulty or not properly calibrated
in NSW if i remember correctly....
Yeh I remember that one last year
i only got one point left aswell :P
Apparently there is a new angle. This from our radar expert on the Roadsense discussion group.
"There will be a segment on Section 10 of The National Measurement Act 1960 re Traffic cases on a Current affair channel 9 Wednesday nite.
It is a very important subject which the system has been avoiding."
TMU  <_<
Not EVERYONE! My last contribution to the state's coffers was back in 2003, and I don't remember the one before that, so I probably have them all available.
But I'll still be watching.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
