, you need to drop the engine out of the way to drill into the firewall. You understand all that right?
Can it be done from inside the car, ie remove the dashboard??
This would be much easier than removing the engine
  • Replies 137
Posted Images
I had the unichip off for a while cos the coil packs are stuffed (think thats it) and would miss terribly over 2500 rpm.
Mainly cos i was in tassie and they dont sell 98ron there.
Since i got to melbourne and running ultimate the uni chip is back on, goes a lot better but still misses under heavy load.
A set of splitfires will be the answer i believe.
yep, checked that as well as threee types of plugs, no good still. Really need to pull my finger out and get it fixed.
Not good when your stag is coughin and spittin and an ET goes past you.
Thats no good at all, it does sound like your coil packs are breakin down, you could repair them, i've seen a few threads on this. Or jus go splitfires but there pretty pricey.
Over time they get hairline cracks in the body of the coil, and under load the coil shorts to any close nearby earth, which is usually the metal ring around the coil which it mounts with.
Quite a few guys have had success sealing these cracks with a few different methods, do a search and u'll definately find some info :P
Ive called APS here and the said it would be around 1500-1600$ for a unichip + boost control kit installed, tuned and drive away....does anyone think that this is actually worth it?
I mean, is a Unichip 1600$ good?
So - do you use your glovebox much?
SAFC - $400 (approx?)
SITC - $250 (either new or 2ndhand)
EBC - $250 (Hybrid dual stage) up to $1000
Setup and tuning - $700
So all of that is roughly $1600 as well & a FULL glovebox - depends which way you want to go really.
EDIT - with fuel regulator, pod filter, full zorst, fmic, etc etc, and the above, 160awkw is nothing to be sneezed at, with easy 200awkw potential with a hiflow turbo.
Edited by bwilkeson
Are there any issues running larger injectors on a stock ECU? Can it run the injectors i mean. If yes, the tune will be for
GCG
Exhaust
FMIC
HF Panel filter
Jaycar EBC 14psi (or whats safe on an RB25 stock internals)
Injectors
Exhaust cam gear
Splitfire coilpacks
DC ATF cooler
Auto Shift kit (maybe in a new gearbox??)
Tomei poncams (??? what lift, duration etc?)
Any ideas on what I can push out of a unichip? I mean, could i push the car to an easy 225awkw+? (better then SITC and DFA?)
On another note I wont need the boost controll kit, so they said take off a few hundred dollars. So lets say 1250....thats good isnt it?
The problem I always find with chipped ECU's is they cost almost as much to update as when they were installed in the first place. That's not so bad if you are going to do all your mods at once and not drive the car until it is tuned. But I never seem to be able to do that, I always end up doing more mods or wanting to try something. A chipped ECU would be a real pain in the ass for me.
I only put the IEBC, DFA and SITC in the glovebox because I don't use the glovebox. The street directory goes in the drivers door pocket, the first aid kit goes in the passengers side door pocket and the CD's go in the pocket on the rear of the passengers seat. The incidentals go in the console. If I wanted to use the glovebox, I would have put them under the passengers seat.
I find this immediate leap of logic from "engine is missing" to "coil packs must be stuffed" most frustating. I have a 420+ rwkw RB31DET running on stock standard, 170,000 k's old, 1990 R32GTST coils packs. I had a 265 rwkw R34GTT, with standard coil packs. The R33GTST that has Alex's Power FC in it has standard coill packs. The R32GTR with the RB30 in it has been running 475 bhp for 6 years on its standard 1989 coil packs. Needless to say the Stagea has standard coil packs in it.
My experience has been that over 95% of engine missing problems has NOTHING to do with coil packs. It is usually ECU R&R mapping, sometimes badly gapped plugs and/or incorrect heat range plugs, very occasionaly it's extemely poor tuning (mega rich). Changing coil packs is a last resort, only to be used when all other methods have failed, not the first port of call.
:D cheers :D
Cheers SK, i was just told to try the coil packs.
I tried 3 different types of spark plugs all gapped to .8mm also other gaps and heat ranges
The car was fine when i got it from canberra. The drive back it went like a dream, but not long after being in Tassie, started to miss under load.
I removed the unichip and it ran a lot better, slower but less missing, and it only missed under decent ammounts of load.
Are reccomended plugs in the parts list thread, otherwise any reccomendations.
This is my first injected car and im slowly learning.
Thanks.
mate i had the same problem as you for ages. it seemed to right itself. Then everytime my turbo boosted more than 10psi it would start missing again. i tried eveything 3 different kinds of plugs even gapped my plugs down to .65 tried putting dielectric grease inside rubber boot of coils. cleaned my coils up and inspected them multiple times. No cracking at all i even looked at them through a magnifiying glass as the problem was driving me mental. After all that i was convinced it wasnt the coils. Until one day i got got sooo sick of having a phat car that i could drive hard because of a stupid little bullshit problem like it breaking up that i was desperate fro a solution. So i bit the bullet ordered a set of splitfires and what do you know it fixed the problem now car will boost to 14psi no ign break up at all. Not to mention feels alot better with them in.
i got them from perfectrun.com.au for 550 delivered.
i know how you feel i nearly went mental. I hate bullshit problems like that. But i will almost guarantee the coils are fkd and you need new ones. I was in denial that i needed new coils as i could see anything wrong with them. But i was wrong and for once my gamble paid off
It may not be the coils but it could be an ignitor problem. I used to have an SR20DET sileighty and one day I was smart enough to wash out the engine bay (I was younger and much more stupid back then :P) and stuffed the TPS, car ran like shit would miss and splutter all over the place and it was still auto then and wouldn't shift properly. I converted it to manual (which I was going to do anyway), fitted a manual TPS and it still missed heaps. I checked over the coils and couldn't find anything wrong but still assumed this was the problem because I fitted a new set of standard NGK plugs gapped to what they should be. Still no good. So I thought just as a test I gapped them RIGHT down and bingo, it still missed a little under high load but nothing like it had been. Then I purchased a set of NGK Platinum plugs and gapped to spec and bingo sweet. So like SK said, if they look in good condition and you can see no signs of arcing then they most likley are. Just as a test try closing the gap on the plugs and see what happens.
  • 2 years later...
hey everyone. just a silly question. ive got a seres 2 stag full 3 inch exhaust and a k&n panel filter. ive got a constant and getting worse miss that im chasing. but thats for another day. has anyone had any real experience with a power fc in a series 2 stag? just considering it as a tunable upgrade.
thanks
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
