Hey guys, im thinking ahead now and am starting to gather parts for my rb25det turbo upgrade.
I'm after around 250-270rwkw and trying to keep the response good for street.
Im going the 2835 pro s, dnt knw which A/R to get yet, but will do more study first, im sure this turbo will suffice for what i'm after.
Just wondering what sort of parts i should buy at the same time to go with the turbo and make it a bit more reliable
To my understanding these turbos can be low mounted so can use most of the stock setup, bar a different dump that comes with the kit. i think this is one reason im really liking this turbo, no need for a highmount manifold, meaning no need for too many extra mods, and looks stealth too:)
Heres my Current setup
r33 25t series 1
apexi pod, h/shield plus cai
Hybrid Fmic
3" exhaust to split dump pipe
Turbotech boost tap ~ 9psi (ppl still use these after bigger turbo, or go EBC)?
18" tyres for what its worth!
Now what i'll be doing before going bigger turbo:
- Compression Test/Leakdown...make sure i have a healthy setup currently:)
- Auto to manual 25t (ogura 4.8kgs lightened flywheel, still deciding on clutch...help???)
- Power FC + Tune....hoping for close to ~200rwkw
- Maybe Bigger fuel pump? - dnt knw whether to go Bosch 040 or 044
I'm not doing the conversion from auto to manual, so i was wondering if theres anything that could be looked at/upgraded while the engine is out???
What else would benefit while doing bigger turbo? cams maybe? injectors, someone told me to lower compression, thicket gasket but im not ready to lose response if i dnt need to!
Edited by nsta
https://www.sau.com.au/forums/topic/105873-gathering-turbo-upgrade-parts/
With that turbo you would probably need injectors and a fuel pump to be safe, and also a Z32 AFM.
I think you'd be right at the limit of the standard AFM and/or injectors at that power level, and probably won't see the best out of your new turbo.
Why not just wait until the turbo is in; put the PowerFC in then and only get it tuned once and save yourself some money??
I doubt you'd need to lower compression at all.
Cams will net you maybe ~15kw extra, is it worth nearly $1000 to you?
Clutch - i'd look at a 9-puck or similar, but that's just my opinion. Still nice and driveable on the street.
(The dollars start adding up quickly if you want to do it properly!)
Edited by Beeble
I have a solid 250 rwkw at 14psi with the GCG highflow and Poncams (260 degree) and 480 cc injectors.
Didn't require the AFM, but if I chase any more power (not likely) I will need the upgrade.
The cams will give you a heaps bigger mid range and hold onto power over a wider span. I'm making more than 240rwkw for over 1500 rpm.
cool thanks, i was thinking about the whole waiting around for the turbo upgrade then going and tuning it all at the same time, though i dnt know how long itll be till i see all the parts, and being able to gather everything.
About the cams, ive only heard good things about it, costly though and i heard that poncoms 256 were more ideal for the r33's?
Im really after a nice clutch for the street, as that will be things that need upgrading 1st as the conversion will need to be done before eveything.Im thinking a single plate would suffice for the power output id like to acheive but others have me saying to go twin plate!, so confused!
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
