Well by saying an API SM oil is good, then I guess everyone can get away with GTX2 then? API specs are not hard to meet. ACEA are tougher.  <_<
Every half decent oil is API SL/SM rated now. Mobil 1 is SM. So is Castrol GTX2. Does that mean they are as good as each other? Obviously not. So by saying Fuchs meets API SM its suddenly a great oil? No. OE certs are usually harder to meet than API standards such as MB and VW's so they are more relavant. (Although I wouldn't expect GT1 to meet OE specs just like 300V, Redline etc)
Looking at raw details such as the base oil, the additive packages and performance in UOAs is more of an indication of how good an oil is, not just what API spec it is. And Fuchs in this regard have shown nothing out of the ordinary.  :D
Then again any oil isnt even at least API rated SL, it doesn't be deserved to be put into any car whatsoever!
Cheers  B)
A great site for UOA results: BITOG
Looking at raw details such as the base oil, the additive packages and performance in UOAs is more of an indication of how good an oil is, not just what API spec it is. And Fuchs in this regard have shown nothing out of the ordinary.  :)
Cheers  B)
I never said Fuchs API SM was suddenly a great oil, I am just trying to help you guys out with some information. Well go buy the oil that your Skyline recomends. You probably dont know what it is. Should be JASO something.
I am not here to try and brain wash anyone that Fuchs is the best, if you read my earlier posts you will see that I said most oil company's are good. But if you are after a MB or VW spec to put into your Nissan, Fuchs will have it as they are initial fill for both
I provided information on Fuchs products and some helpfull information. Now im geting shot down for trying to help people. no wonder i stopped visiting this site!
Go pay $100 for Redline and drain it after 5000 kms I dont care. If you think i am tring to do this to help Fuchs sales in retail your mistaked. One decent size transport or earthmoving company spends more per year on lubes than several autoshops put together.
You believe your car is demanding on oil. Think about how much work a lube has to do when towing 128 tons thru heat and dust and not be drained until 80,000 kms. Or a 18 speed roadranger gearbox doing 500,000 kms per drain.
By the way everybody would get away with GTX2. It would take anything you guys could dish out.
ASH
Wow man take a chill pill. Its just a discussion forum. I never meant to offend you. My apologies if I came about this way. I didnt read that you work for Fuchs either. Actually I would have a few questions heheh..
Anyways oils are like peoples favourite drink, no matter how good a drink is to you, others may still not like it.
Cheers.
Edited by Busky2k
ASH
Hey kingscorp, we appreciate your sharing of knowledge with us on Fuchs lubricants. We are also learning everyday, peace. I think what Busky2k is trying to say is API standard is pretty normal, almost all decent oil brand can make it. It's the ACEA A3 standard which must meet a min HTHS of 3.5 or MB 229.3 standard which separate the good among the average oil.
Anyway what i think is most important in a oil are the
HTHS figure ( for Hydrodynamic lubrication)
anti-wear additives ( for boundary lubrication)
surfactant, detergent level ( engine cleanliness)
Perhap with your insider knowledge, you could disclose some data of fuchs lubricant for our discussion.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
