Well by saying an API SM oil is good, then I guess everyone can get away with GTX2 then? API specs are not hard to meet. ACEA are tougher.  <_<
Every half decent oil is API SL/SM rated now. Mobil 1 is SM. So is Castrol GTX2. Does that mean they are as good as each other? Obviously not. So by saying Fuchs meets API SM its suddenly a great oil? No. OE certs are usually harder to meet than API standards such as MB and VW's so they are more relavant. (Although I wouldn't expect GT1 to meet OE specs just like 300V, Redline etc)
Looking at raw details such as the base oil, the additive packages and performance in UOAs is more of an indication of how good an oil is, not just what API spec it is. And Fuchs in this regard have shown nothing out of the ordinary.  :D
Then again any oil isnt even at least API rated SL, it doesn't be deserved to be put into any car whatsoever!
Cheers  B)
A great site for UOA results: BITOG
Looking at raw details such as the base oil, the additive packages and performance in UOAs is more of an indication of how good an oil is, not just what API spec it is. And Fuchs in this regard have shown nothing out of the ordinary.  :)
Cheers  B)
I never said Fuchs API SM was suddenly a great oil, I am just trying to help you guys out with some information. Well go buy the oil that your Skyline recomends. You probably dont know what it is. Should be JASO something.
I am not here to try and brain wash anyone that Fuchs is the best, if you read my earlier posts you will see that I said most oil company's are good. But if you are after a MB or VW spec to put into your Nissan, Fuchs will have it as they are initial fill for both
I provided information on Fuchs products and some helpfull information. Now im geting shot down for trying to help people. no wonder i stopped visiting this site!
Go pay $100 for Redline and drain it after 5000 kms I dont care. If you think i am tring to do this to help Fuchs sales in retail your mistaked. One decent size transport or earthmoving company spends more per year on lubes than several autoshops put together.
You believe your car is demanding on oil. Think about how much work a lube has to do when towing 128 tons thru heat and dust and not be drained until 80,000 kms. Or a 18 speed roadranger gearbox doing 500,000 kms per drain.
By the way everybody would get away with GTX2. It would take anything you guys could dish out.
ASH
Wow man take a chill pill. Its just a discussion forum. I never meant to offend you. My apologies if I came about this way. I didnt read that you work for Fuchs either. Actually I would have a few questions heheh..
Anyways oils are like peoples favourite drink, no matter how good a drink is to you, others may still not like it.
Cheers.
Edited by Busky2k
ASH
Hey kingscorp, we appreciate your sharing of knowledge with us on Fuchs lubricants. We are also learning everyday, peace. I think what Busky2k is trying to say is API standard is pretty normal, almost all decent oil brand can make it. It's the ACEA A3 standard which must meet a min HTHS of 3.5 or MB 229.3 standard which separate the good among the average oil.
Anyway what i think is most important in a oil are the
HTHS figure ( for Hydrodynamic lubrication)
anti-wear additives ( for boundary lubrication)
surfactant, detergent level ( engine cleanliness)
Perhap with your insider knowledge, you could disclose some data of fuchs lubricant for our discussion.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
