YES its on again. I will be placing another order for goods from Japan.
Date of order: 12 July
Date funds are to be IN my account: 11 July
Following are the details. Read carefully.
1.
All you have to do is email me with the item you wish to order. I can get practically anything you want so just ask me. At this stage I will not be ordering large items like exhausts and bodykits as the shipping is yet to be worked out so that I can quote correctly.
2.
Once you have emailed me I will send you a quote. The price I give you is final and not negotiable, I am not in this to make money but I do have to cover all my cost and the fact that if the yen changes I have to bear the difference. The price you receive will include shipping to your door.
3.
If you are happy with the quote and you wish to participate with the buy then just email me with notice that you have deposited the necessary funds into my account. I must have all funds IN my account by the 11th of July, there for you may need to deposit the money a couple of days prior to this date to ensure I get it on time. I also require at this point your shipping address.
4.
Once I receive the funds I will notify you of that and place the order on the 12th July. After that I will keep you informed as to the progress of the order only when I hear from the supplier.
5.
Upon me receiving the goods I will post to you as soon as possible by normal mail.
WHY BUY WITH ME:
The reason why I suggest you be part of this buy is to help reduce the cost of the shipping for your goods. Also, because I have placed many orders I believe that I get better feedback from the various companies that I use.
Please don't reply to this message. I will only respond to private email at [email protected]
https://www.sau.com.au/forums/topic/1059-japan-group-buy-ii/
TOMEI HICAS LOCK KIT SUIT R32 GTST
Hope it's not too late for my order. can have money in your account instantly. Sorry for late notice, please call me on 0411 878 961
Sam
https://www.sau.com.au/forums/topic/1059-japan-group-buy-ii/#findComment-30417
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
